Porting 516 Heads #769063
08/08/10 08:09 PM
08/08/10 08:09 PM
WI. U.S.A.
DusTed74 Offline OP
DusTed74  Offline OP
WI. U.S.A.
Has anyone ever ported a set of 516 heads using the Mopar templates? If so what were your results?
Thanks in advance..........Ted
Re: Porting 516 Heads [Re: DusTed74] #769064
08/08/10 08:48 PM
08/08/10 08:48 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
There used to be a long and informative post in the archives dealing with ported 516 and 906 heads. Lot of interesting reading in that one if it's still around. Dwayne Porter wrote it, IIRC.
Re: Porting 516 Heads [Re: bobby66] #769065
08/08/10 09:25 PM
08/08/10 09:25 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
no idea how to do it, but I have 516's with 2.14/1.81's and the flow really well. I have the numbers in the garage but I think it's like 270/190 @ .500
Coming soon!!!!
Re: Porting 516 Heads [Re: Mr.Yuck] #769066
08/08/10 09:27 PM
08/08/10 09:27 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yuck I had a set also.Mine were reworked some with the ports and bigger valves.I know my machinist said you had to be careful with the bigger valves and the porting.He was doing a set and hit water.Mine were great and now reside on my kids 62 300.I went Stealths.Rocky
Chrysler Firepower
Re: Porting 516 Heads [Re: DusTed74] #769067
08/09/10 11:58 AM
08/09/10 11:58 AM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
The templates worked fine. I did a set a while ago. First I had the machine shop do a 75 degree throat cut in the pockets. a lot of metal came out and saved me work. Install a 1.74 exhaust valve. Those heads are 84cc from the factory, will give you a slight increase in compression, but you can use them for a quench motor build. Put in on paper first. If it cost too much there are better options!
