indy ez1 or edelbrocks #768541
08/08/10 03:31 PM
08/08/10 03:31 PM
mi
dirty magnum Offline OP
mi
how much power difference is there on a 500 ci street , strip motor ? arond 9-1 comp, flat tappet cam. anybody ever run both and see?
Re: indy ez1 or edelbrocks [Re: dirty magnum] #768542
08/08/10 04:03 PM
08/08/10 04:03 PM
AndyF Offline
AndyF  Offline
There are some articles in the tech archives that I wrote where I dyno tested Edelbrock heads and then switched to Indy EZ heads.
Re: indy ez1 or edelbrocks [Re: dirty magnum] #768543
08/08/10 07:45 PM
08/08/10 07:45 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Wht would you run 9to1 compression with alum heads?
Re: indy ez1 or edelbrocks [Re: dirty magnum] #768544
08/08/10 10:37 PM
08/08/10 10:37 PM
mi
mi
andy i read the articles , how much power did you make with the ez heads stock before jeff worked his magic? great articles by the way.
Re: indy ez1 or edelbrocks [Re: dirty magnum] #768545
08/08/10 11:03 PM
08/08/10 11:03 PM
AndyF Offline
AndyF  Offline
OOTB EZ heads made zero additional power over the Eddy heads. Once the EZ heads were CNC ported then we picked up about 100 hp.
Cam, compression and engine size will all add into the mix but the 100 hp gain that Indy advertises is very real on the right shortblock.
