Manley 221447 Nextek Spring and HEMI pushrods question.
#768483
08/08/10 02:01 PM
08/08/10 02:01 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
Edited: Problem Solved.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
Re: Manley 221442 Nextek Spring and HEMI pushrods question.
[Re: PUNK]
#768484
08/08/10 02:13 PM
08/08/10 02:13 PM
PUNK
Edited: Problem solved
[Re: PUNK]
#768485
08/08/10 02:21 PM
08/08/10 02:21 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
I have heard(to me) Terry say that the pushrod rubbing against the head is not a bad thing, it helps stablized the pushrod like a guide plate does ![](/ubbthreads/images/graemlins/shock.gif) After having to replace three single tapered pushrod on a customers engine due to the exhaust pushrods rubbing enough to not allow oil into the cups and burning the tips up I ground the head and the block to make sure the pushrods had enough clearance to rotate freely when the valves where closed ![](/ubbthreads/images/graemlins/thumbs.gif) Is there any reason to not grind the head or block to run the best pushrod?
[Re: Cab_Burge]
#768486
08/08/10 02:36 PM
08/08/10 02:36 PM
PUNK
[Re: PUNK]
#768487
08/08/10 02:42 PM
08/08/10 02:42 PM
PUNK
