I have had an electrical problem in the past,had to replace under dash harness,engine comp.harness,coil,ecu box,dist p.u.coil,dash circut board,voltage limiter, due to a short in the harness.Im" thinking there still may be a problem,possible with the ignition wire (alt. rebuild guy mentioned it) ,the blue one? I don"t know where it is or how to check it? About a year ago I fixed everything I mentioned and now Ihad to have the alt. rebuilt again.Iam afraid that I am going to have problems with the alt.if I don"t get this problem fixed.Any suggestions would be appreciated? Thanks Aian
