Re: Carter carb problems
[Re: 66droptop]
#768066
08/08/10 12:13 AM
08/08/10 12:13 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
These old carbs don't get any love here. I am curious if you have 2 gaskets between the top and the bowl? Is the throttle shaft loose? The tops warp like crazy on these carbs. Mine take a ride on the belt sander to true them up. Bowl too. I have a few of these carbs and I have rebuilt a '65 model for my slant. I don't think there is any adjustment on the metering rods. The later BBD's (76 and newer IIRC) did. You may have to go to www.slantsix.org for people that know these carbs.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: 66droptop]
#768067
08/08/10 03:28 AM
08/08/10 03:28 AM
RapidRobert
What's the accel pump squirt look like? when did it start hesitating? any changes done right before it started?
[Re: 66droptop]
#768069
08/08/10 10:42 AM
08/08/10 10:42 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Sometimes carb kits come with more than one set of gaskets in them. This is so they can cover more years with less part numbers. What this means is that you may have installed the wrong gasket and are possible blocking something. Another possibility is that your transfer slot is plugged, possibly when you scraped the old gasket off?
From your description is sounds like under mild acceleration you get a hesitation, this is transfer slot territory, not accelerator pump territory.
Your mileage is most likely being affected by the 3 turns out on the idle screws. I would blow out the transfer circuit and readjust the idle screws.
[Re: 66droptop]
#768070
08/08/10 11:15 AM
08/08/10 11:15 AM
RapidRobert
It started hesitating after I replaced the gaskets,pump and needle and seat. Also,I have to turn the idle mixture screws out 3 full turns before it runs better..
Open it up & a good visual to find what went wrong. The gaskets, compare the new to the old/some have to go on one way (top/bottom) and the 3 turns is it making up for the vac leak. Does it squirt immediately when you barely touch the throttle (& clarify on the 2 squirts) EDIT did you mean it has enough gas for 2 good squirts then just a dribble? Check the float level
[Re: RapidRobert]
#768071
08/11/10 08:57 PM
08/11/10 08:57 PM
Posts: 309 S.e. lower MIch..
66droptop
S.e. lower MIch..
I took it apart and the gaskets looked fine,like the old ones just no tears in them. I did not by a rebuild kit ,I only got the 2 gaskets and the needle and seat. The carb is very clean on the inside like I figured. Question 1:I found the seat that I had before and compared it to the new one I got.It looks the same but when I put the new needle in the old seat it went down in the seat further.So does that affect my float level with the new seat.Well i adjusted the floats but think I went to far and now I think there is too much gas. After I get the car running and turn it off I looked down the barrel and saw gas leaking into the bottom of the carb. What is the best way to measure the float.Is 1/4" when the carb is turned upside down.
Also,when I took the new seat off the carb, there was no gasket there.Shoudn't there be soon kind of gasket?
[Re: RapidRobert]
#768074
08/14/10 10:18 PM
08/14/10 10:18 PM
66droptop
S.e. lower MIch..
Well the hesitation is gone which is very good. Still have to turn the screws out 3-3 1/2 turns to get it to idle smooth,although it still seems a little rough.Do you mean a vaccum leak in the carb or somewhere else. Also,I back into my drive and when going from the street to the drive there is a kind big incline and you need to give it a little gas,after getting over the hump if you let up on the gas it wants to stall.But give it a little gas and it is fine...Is this still a float issue???
[Re: 66droptop]
#768075
08/14/10 10:29 PM
08/14/10 10:29 PM
Posts: 3,318 Great White North
Wheeler
Great White North
66droptop - Did you replace the carb base gasket by chance? It's a 1/4 inch gasket that sits in between the carb and the intake manifold.
I had a similar problem years ago with a 1985 Dodge Truck (318 with Q-Jet 4bbl carb). One day, the engine didn't want to idle smooth and would stall if you let off the gas. Turned out it had a bad carb base gasket, causing a vacuum leak. I replaced the base gasket and it fixed the problem.
Hope this helps - good luck.
[Re: 66droptop]
#768077
08/15/10 12:46 AM
08/15/10 12:46 AM
RapidRobert
was it hesitating before you took the carb apart or did you open it up because of the poor mileage? Did the base gasket you used match the old one?
