Valve spring size needed? #767842
08/07/10 04:15 PM
08/07/10 04:15 PM
Kentucky
dfsmopars Offline OP
Kentucky
I am going to install a Comp Xtreme cam in my bone stock 318 this Winter. The cam is a .462/.470 lift. I'd like to pick up valve springs at the Nats if I see a good opportunity. What size springs should I be looking for? What brand would be good?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Valve spring size needed? [Re: dfsmopars] #767843
08/07/10 04:56 PM
08/07/10 04:56 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
buy the comp 901 spring...
Tony
70 AARCuda Vitamin C
Re: Valve spring size needed? [Re: 70AARcuda] #767844
08/07/10 07:51 PM
08/07/10 07:51 PM
Kentucky
Kentucky
Thanks, I see that one listed on the box. I'll see what I can find.
Re: Valve spring size needed? [Re: dfsmopars] #767845
08/07/10 09:48 PM
08/07/10 09:48 PM
scratchnfotraction Offline
you want comp 901-16
they are a single with damper
use stock retainers and stock seals
can be installed heads on the engine also
if the 318 heads have rotators on the exhast valves..ditch those and get 8 more intake retainers
the rotator limet the lift and add to coil bind measurement
you will know a rotater when you see it,thick and uses a shorter spring,its a bearing so the valve spins in the guide
