mopaint to dye interior parts #76707
06/20/08 09:49 PM
06/20/08 09:49 PM
cmansell Offline OP
cmansell  Offline OP
Any one used mopaint in spray can to dye dash pad and plastic interior parts? Im have a nice 69 black pad I need to change to red.
Re: mopaint to dye interior parts [Re: cmansell] #76708
06/20/08 10:23 PM
06/20/08 10:23 PM
Franksville, WI
g-man70 Offline
g-man70  Offline
Franksville, WI
A year ago, I dyed my black upper door pads to white along with some other black plastic interior parts. Color match was right on and is holding up well. They recommended cleaning parts with simple green cleaner prior to dying. I would certainly use their dye again.
Re: mopaint to dye interior parts [Re: cmansell] #76709
06/21/08 12:12 AM
06/21/08 12:12 AM
Santa Fe,Texas
TexasMopar Offline
TexasMopar  Offline
Santa Fe,Texas
I have had good luck using their paint.
Re: mopaint to dye interior parts [Re: TexasMopar] #76710
06/21/08 02:15 AM
06/21/08 02:15 AM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
i've also had good luck with there paint,as said clean with simple green first,i don't remember who told me but it works great if after simple green rub parts down with rubbing alcohol.works great good luck
Re: mopaint to dye interior parts [Re: meepmeep70] #76711
06/21/08 09:29 AM
06/21/08 09:29 AM
cmansell Offline OP
cmansell  Offline OP
thanks for the simple green tip, I will test it on the plastic before the dash pad.
