Master cylinder bench bleeding question #766812
08/06/10 09:32 AM
08/06/10 09:32 AM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
I'm trying to bleed my manual brake master cyl.in a vice, and all I am getting through the lines(going back to the reservoir)are spurts of air and a little fluid.I've pumped this for about 10-15 min. and still the same.What am I doing wrong?
Thanks Moparts
Re: Master cylinder bench bleeding question [Re: 5carguy] #766813
08/06/10 09:48 AM
08/06/10 09:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the ends of your bleed lines are in the fluid in the reservoir , correct ?
Re: Master cylinder bench bleeding question [Re: JohnRR] #766814
08/06/10 10:22 AM
08/06/10 10:22 AM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
No,the lines are just above the fluid.Is that what the problem is?
Re: Master cylinder bench bleeding question [Re: 5carguy] #766815
08/06/10 10:52 AM
08/06/10 10:52 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
yes, it is sucking air back in when u release .
Re: Master cylinder bench bleeding question [Re: 05dakota] #766816
08/06/10 12:13 PM
08/06/10 12:13 PM
None
71rm23 Offline
71rm23  Offline
None
Re: Master cylinder bench bleeding question [Re: 71rm23] #766817
08/06/10 04:31 PM
08/06/10 04:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
X3 , I knew you were going to say that ...
