Re: Mopar Action article on power steering modification?
[Re: Pacnorthcuda]
#766520
08/07/10 06:25 PM
08/07/10 06:25 PM
Posts: 16,813 Between Houston & Galveston TX
SattyNoCar
I was flipping thru some of my old issues of Street Rodder about a month or so ago and came across on article where they installed a valve inline to regulate the pressure. I'd have to find the issue again to tell you who made it.
Seemed like an easier (though not cheaper) solution.
John
[Re: thedriver]
#766523
08/07/10 09:36 PM
08/07/10 09:36 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
I'd be interested in this too as my pump is out at the moment.
What is it, some kind of washer to restrict the flow?
Scott
1969 Super Bee, 383/4 speed
[Re: StukaJU87]
#766524
08/07/10 09:39 PM
08/07/10 09:39 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
No its just a washer (of a certain thickness, again I think about .031) to compress the valve/spring assembly in the high pressure line a little more than stock. Simple simple simple. I just have never tried it or heard from those who have...
[Re: Pacnorthcuda]
#766525
08/15/10 12:01 PM
08/15/10 12:01 PM
Posts: 19,383 north of coder
moparx
well guys, i had a "super meltdown" on this stoopid pooter last friday/saturday and lost everything. i just got back online as of this morning, and i think my scanner is fried. the basic idea of this article is that a "shim" is inserted into the spool valve on the pressure side [outlet] that lowers the output pressure from approximately 1400# to somewhere around 750-825#. this makes a very noticeable difference ! i like it a lot ! but the hard part is getting the correct washers to use as shims. e-booger recommends adding approximately .062[1/16th"] to whatever shim[s] you may currently have in your stock valve. the shim washers are 1/2"od.x 3/8" id. one way is to drill out a 1/2" od. washer to 3/8", which is almost impossible to hold. what i did was to stack some 3/8" id copper washers on a bolt and turn 'em down on the lathe. super easy to do. if anyone wants some, let me know and i'll whip up a batch. as to when i can scan the article, it may be a couple of days yet. i will try to take a photo and see how that works. to the original poster, please accept my appologies if this has caused you any delays in your project !
[Re: rutro]
#766530
08/15/10 12:55 PM
08/15/10 12:55 PM
Posts: 553 DE
Ply72rr
DE
These shims should work and come in different thickness for fine tuning the pressure. Stainless Steel Round ShimsClick on "round Shims",Choose "Bearing",Click on ".498 outside diameter."
[Re: moparx]
#766531
08/15/10 02:08 PM
08/15/10 02:08 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
last page
When I click on Attachment, the pages are too small to read.
[Re: BrianShaughnessy]
#766535
08/16/10 10:32 PM
08/16/10 10:32 PM
moparx
pic#1
I damn near threw up trying to get the pictures for that article.
sorry guys. i did the best i could with my camera. my scanner is toast
