Re: Heater & By-Pass Hose Nipples- Tool for Installing?
[Re: In_The_Pink]
#76599
06/20/08 07:05 PM
06/20/08 07:05 PM
RapidRobert
no, just use a correctly sized piece of steel.
[Re: In_The_Pink]
#76603
06/21/08 08:46 AM
06/21/08 08:46 AM
Posts: 6,224 JERSEY
RJS
JERSEY
Maybe I should re-phrase my question...
When engines were originally assembled, what was used to tighten the heater and by-pass hose nipples?
I'd like to know too!!!
[Re: In_The_Pink]
#76605
06/21/08 09:58 AM
06/21/08 09:58 AM
Posts: 511 Jasper, Indiana
fastnos
Jasper, Indiana
How about a drag link socket?
A True Hybrid: Burns Gas AND Rubber!
[Re: gtx6970]
#76607
06/21/08 05:16 PM
06/21/08 05:16 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
I'm guessing but OE installs were probably a special socket designed with keys inside it to align with the slots
This is what I was thinking, but was there never a special service tool (or whatever Mopar called their specific tools) that they used at dealerships back in the day? Surely they didn't use Vice-Grip(tm) pliers evry time.
[Re: In_The_Pink]
#76608
06/21/08 08:35 PM
06/21/08 08:35 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
ahhh , why wouldn't they ??
what engine are you looking for this non existent tool for ?
[Re: JohnRR]
#76609
06/21/08 08:46 PM
06/21/08 08:46 PM
In_The_Pink
Milwaukee, WI
Um, because they are professional mechanics.
Just your standard Small Block LA engine, but the application isn't important really.
You can use a screwdriver and hammer to remove an ignition switch bezel, but we all know there's a correct tool designed for removeing the bezel. I just want to know if there is such a tool for installing and removing heater hose nipples. Maybe it doesn't exist, I dunno...that's why I'm asking.
[Re: JohnRR]
#76611
06/21/08 10:10 PM
06/21/08 10:10 PM
moparpollack
Lil Herman
Lil Herman
85086
Yup all the Chrysler mechanics back then had every tool in the manuals and never skipped a step or used a homemade tool.
[Re: In_The_Pink]
#76614
06/22/08 12:12 AM
06/22/08 12:12 AM
JohnRR
Back to the question, was there ever a master list of Special Service tools?
are you unable to finish assembling your engine without the tool or is this for your doctorite in auto technology ???
... it was a joke son ...
i just looked thru my 69 shop manual , there is not torque spec , no tool listed and not even a procedure to do what you are asking about .
maybe you should have asked this question in the over restored section ???
[Re: hemi71x]
#76615
06/22/08 01:30 AM
06/22/08 01:30 AM
In_The_Pink
Milwaukee, WI
Miller Special Tools manufactures Chrysler Corporation service tools. I have quite a few of their catalogs going back to the mid 70's. Never have seen anything in any of the catalogs for a "special tool" used on the hose fitting nipples.
Thanks.
[Re: In_The_Pink]
#76616
06/22/08 01:59 AM
06/22/08 01:59 AM
Posts: 553 DE
Ply72rr
DE
