Page 1 of 3 1 2 3
Heater & By-Pass Hose Nipples- Tool for Installing? #76598
06/20/08 05:52 PM
06/20/08 05:52 PM
Milwaukee, WI
In_The_Pink Offline OP
Milwaukee, WI
Is there a special tool for installing heater hose and by-pass hose nipples into intake manifolds?
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: In_The_Pink] #76599
06/20/08 07:05 PM
06/20/08 07:05 PM
no, just use a correctly sized piece of steel.
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: RapidRobert] #76600
06/20/08 09:28 PM
06/20/08 09:28 PM
IN
ahy Offline
ahy  Offline
IN
Or a heavy (say 1") washer turned by a screwdriver or Crescent wrench.
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: ahy] #76601
06/20/08 11:18 PM
06/20/08 11:18 PM
better yet
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: RapidRobert] #76602
06/21/08 12:00 AM
06/21/08 12:00 AM
Milwaukee, WI
Milwaukee, WI
Maybe I should re-phrase my question...
When engines were originally assembled, what was used to tighten the heater and by-pass hose nipples?
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: In_The_Pink] #76603
06/21/08 08:46 AM
06/21/08 08:46 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I'd like to know too!!!
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: RJS] #76604
06/21/08 09:44 AM
06/21/08 09:44 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I'm guessing but OE installs were probably a special socket designed with keys inside it to align with the slots
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: In_The_Pink] #76605
06/21/08 09:58 AM
06/21/08 09:58 AM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
How about a drag link socket?
A True Hybrid: Burns Gas AND Rubber!
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: In_The_Pink] #76606
06/21/08 03:37 PM
06/21/08 03:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A hose nipple tool is easy to make, just take a deep nut and grind/file the face to leave two blades that fit the slot in the nipple and then thread a bolt shank into it to act as a pilot.
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: gtx6970] #76607
06/21/08 05:16 PM
06/21/08 05:16 PM
Milwaukee, WI
Milwaukee, WI
This is what I was thinking, but was there never a special service tool (or whatever Mopar called their specific tools) that they used at dealerships back in the day? Surely they didn't use Vice-Grip(tm) pliers evry time.
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: In_The_Pink] #76608
06/21/08 08:35 PM
06/21/08 08:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
ahhh , why wouldn't they ??
what engine are you looking for this non existent tool for ?
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: JohnRR] #76609
06/21/08 08:46 PM
06/21/08 08:46 PM
Milwaukee, WI
Milwaukee, WI
Um, because they are professional mechanics.
Just your standard Small Block LA engine, but the application isn't important really.
You can use a screwdriver and hammer to remove an ignition switch bezel, but we all know there's a correct tool designed for removeing the bezel. I just want to know if there is such a tool for installing and removing heater hose nipples. Maybe it doesn't exist, I dunno...that's why I'm asking.
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: In_The_Pink] #76610
06/21/08 08:48 PM
06/21/08 08:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
now thats some funny stuff right there
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: JohnRR] #76611
06/21/08 10:10 PM
06/21/08 10:10 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Yup all the Chrysler mechanics back then had every tool in the manuals and never skipped a step or used a homemade tool.
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: moparpollack] #76612
06/21/08 10:56 PM
06/21/08 10:56 PM
Milwaukee, WI
Milwaukee, WI
Back to the question, was there ever a master list of Special Service tools?
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: In_The_Pink] #76613
06/21/08 11:17 PM
06/21/08 11:17 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Miller Special Tools manufactures Chrysler Corporation service tools.
I have quite a few of their catalogs going back to the mid 70's.
Never have seen anything in any of the catalogs for a "special tool" used on the hose fitting nipples.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: In_The_Pink] #76614
06/22/08 12:12 AM
06/22/08 12:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
are you unable to finish assembling your engine without the tool or is this for your doctorite in auto technology ???
... it was a joke son ...
i just looked thru my 69 shop manual , there is not torque spec , no tool listed and not even a procedure to do what you are asking about .
maybe you should have asked this question in the over restored section ???
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: hemi71x] #76615
06/22/08 01:30 AM
06/22/08 01:30 AM
Milwaukee, WI
Milwaukee, WI
Thanks.
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: In_The_Pink] #76616
06/22/08 01:59 AM
06/22/08 01:59 AM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Pipe wrench?
Re: Heater & By-Pass Hose Nipples- Tool for Installing? [Re: Ply72rr] #76617
06/27/14 10:28 PM
06/27/14 10:28 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
I make hose nipple install tools for customers from time to time from tough 316 stainless steel. They include all 3 hose sizes including the small block bypass hose. This is the best way to install them for sure.
Page 1 of 3 1 2 3
