max stall #766001
08/05/10 11:04 AM
08/05/10 11:04 AM
detroit mich
stevehiss Offline OP
detroit mich
all things beings equal , big blocks only
what would be considered a MAX stall speed amount for a drag race attempt
3100-3300 lbs
typical stroker like most might find on the board
maybe 9.90-10-10
I DARE TO BE DIFFERENT
Re: max stall [Re: stevehiss] #766002
08/05/10 11:09 AM
08/05/10 11:09 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
WAXER
Re: max stall [Re: QWK_ENUF] #766003
08/05/10 01:18 PM
08/05/10 01:18 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
6000 flash per playback in my car. It's an 8in ATI set up for a stock stroke small block. Engine is a 512 rb. 9.80's-9.90's 137-138mph
Re: max stall [Re: stevehiss] #766004
08/05/10 01:36 PM
08/05/10 01:36 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I thought you usually want the converter to stall at the engines max torque peak. Maybe even a bit higher depending on RPM drop between gears?
Re: max stall [Re: stevehiss] #766005
08/05/10 05:16 PM
08/05/10 05:16 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my 3000lb car running 9.57@139 mph has a TA 8" converter that stalls at 5600. 488 gears with 32x14 slicks. cam is 272@050 650 lift, 1025 cfm carb on -1 heads. i cross the stripe at 7200.
Re: max stall [Re: rebel] #766006
08/06/10 10:47 AM
08/06/10 10:47 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
i am trying a new 5600 stall this sat in the 10.0 class. was 5200 stall
WAXER
Re: max stall [Re: QWK_ENUF] #766007
08/06/10 11:39 AM
08/06/10 11:39 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
any exact answer is relative to each car due to variations in a combo. a good a starting point is in the 5500-6000 range
home of the
Sox and Martin Hemi Duster
Re: max stall [Re: HEMIFRED] #766008
08/06/10 12:32 PM
08/06/10 12:32 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I think 1000-1200 below your shift point is good.
Getting old just means you were smarter than some and luckier than others.
Re: max stall [Re: stevehiss] #766009
08/06/10 01:15 PM
08/06/10 01:15 PM
One thing to keep in mind when ordering a converter(buy a really good one for 9 second cars )is thtat the converter will have a differnt flash RPM in low gear versus high gear I have several different converters, 10 inch Contintental, nine inch TA and a eight inch TA. Another dilema is the motor output on the dyno versus what it likes to be shifted at in the car My 518 CI pump gas street motor made peak torque at 4500 RPM and peak power at 5600 RPM, Eddy RPM heads and a six pak intake and carbs. The stupid motor likes to be shifted at or above 7000 RPM with the ten inch converter and below 7000 RPM with the nine inch TA converter Like everything else in a race car you will have to test starting line stall and shift points to find the best RPM for each on your car
