Who's the parts interchange GURU? Timing Chain question #765828
08/05/10 01:05 AM
08/05/10 01:05 AM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
Will a 239 / 3.9 OHV V6 Timing Components 87-91 3 Pc. set. Double roller, also fit a small block 318 LA????
Go Fast and Swerve!
Re: Who's the parts interchange GURU? Timing Chain question [Re: way2fast] #765829
08/05/10 01:24 AM
08/05/10 01:24 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Looks the same...look it up on rockauto; 1990 D150 3.9 and 5.2 and 5.9 all use the same timing set part number.
Re: Who's the parts interchange GURU? Timing Chain question [Re: way2fast] #765830
08/05/10 08:00 AM
08/05/10 08:00 AM
scratchnfotraction Offline
yes,you can use the chain tensioner for the v-6 also
it replaces the cam thrust plate with another plate and has the tensioner on it
takes 3 hands to install it with a new chain but is a good upgrade for the sb
sb are hard on the t-chains
I used one with a chain that had a coauple thousand miles and it went on mucho ez with a tad of slack on the chain
timming has been rock solid and no problems from it
that v-6 is a 318 with the 2 back cyls cut off anyways
Re: Who's the parts interchange GURU? Timing Chain question [Re: scratchnfotraction] #765831
08/05/10 10:50 AM
08/05/10 10:50 AM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
That's what I thought just wanted to confirm before I wasted any $$ Thanks!!!!!!!!
Go Fast and Swerve!
Re: Who's the parts interchange GURU? Timing Chain question [Re: way2fast] #765832
08/05/10 11:26 AM
08/05/10 11:26 AM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
Ok now I'm really confused the pic of the new one does not seem to have a keyway in the cam sprocket..but holes like for a chevy cam??? I just looked at my old double row and it has no holes just the keyway??
here's the new one..
[image][/image]
Go Fast and Swerve!
Re: Who's the parts interchange GURU? Timing Chain question [Re: way2fast] #765833
08/05/10 03:37 PM
08/05/10 03:37 PM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
Cam sprockets are usually located by a locating pin(hence the small single hole outside the cam snout hole) Your timing chain gear also appears to be for a 3 bolt cam.
Re: Who's the parts interchange GURU? Timing Chain question [Re: Dusted_Ya] #765834
08/05/10 03:50 PM
08/05/10 03:50 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Looks like a big block setup.
