Swapping my 906 heads for 452's need some advice #765752
08/05/10 12:21 AM
08/05/10 12:21 AM
NC
Sixt8Chrgr Offline OP
NC
I have a 68 Charger with a stock 383 four barrel. My stock 906 casting have broken casting where the valve cover fasten on the ends of the heads. I have a set of 452 casting I would like to put on the motor. Are there any issues to be concerned with here? Will these heads affect the compression ratio? It is not real high now.
Thanks,
Re: Swapping my 906 heads for 452's need some advice [Re: Sixt8Chrgr] #765753
08/05/10 01:06 AM
08/05/10 01:06 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
take them to your local machine shop and have them cut .020 "
3 angle valve job , check guides for wear , new seals
use the stel shim head gasket .019" thick
now you got better than 906 as they have hardened ex seats to use with todays gas !
Re: Swapping my 906 heads for 452's need some advice [Re: calrobb2000] #765754
08/05/10 03:11 AM
08/05/10 03:11 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The answer to the question is.....The chamber size of these 2 heads are about the same. If you decide to just replace one head, make sure to use the same thickness head gasket.
The previous response makes sense. I would follow the advice and burn some rubber!
Re: Swapping my 906 heads for 452's need some advice [Re: Kern Dog] #765755
08/05/10 09:11 AM
08/05/10 09:11 AM
NC
NC
when you say cut you mean shaved down right?
Re: Swapping my 906 heads for 452's need some advice [Re: Sixt8Chrgr] #765756
08/05/10 09:34 AM
08/05/10 09:34 AM
Upstate New York
zeke Offline
super gas
zeke  Offline
super gas
Upstate New York
452's are pretty much a 906 with hardened valve seats. I'd do a valve job and run them.
A real man would never be caught in a "BOWTIE" !!
Re: Swapping my 906 heads for 452's need some advice [Re: zeke] #765757
08/05/10 10:58 AM
08/05/10 10:58 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Like mentioned same heads basically. Take them have have them checked out. If you mill them you can pump your compression some. This would be a good time to do some upgrades. Intake, carb, headers,,,,,
Coming soon!!!!
Re: Swapping my 906 heads for 452's need some advice [Re: Sixt8Chrgr] #765758
08/05/10 08:54 PM
08/05/10 08:54 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Most of the time they all mean the same....Cut, Milled, Shaved, Machined........
