Hesitation / Bog with new combo ??? #765704
08/05/10 12:05 AM
08/05/10 12:05 AM
Marcell, MN
68 Roadrunner Offline OP
Marcell, MN
Still working the bugs out of my new 383. After sending the "stock" style Mopar Electronic ignition back to Jegs and ordering a Pertronix Flamethrower Distributor with ignitor III it is running again. It seems to run great except for a flat spot right off idle. If I really stab the throttle fast it will actually die. I'm not sure where to start because I have never really had it running perfect since I built the motor. Any suggestions...Carb? Ignition? Timing? I have tried setting the initial anywhere between 12-16 and it made no difference. I don't know what the full advance is going to. I put the lightest springs in the vacuum advance tonight and I will see if it makes any difference tomorrow.
1968 Roadrunner 383 auto .060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
Re: Hesitation / Bog with new combo ??? [Re: 68 Roadrunner] #765705
08/05/10 12:33 AM
08/05/10 12:33 AM
check: accellerator pump shot (should have a squirt immediately on tip in)/float level/ jetting not too lean/vac leak. ported timing?
Re: Hesitation / Bog with new combo ??? [Re: 68 Roadrunner] #765706
08/05/10 08:37 AM
08/05/10 08:37 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Umm...
What's on there for a carb?
Re: Hesitation / Bog with new combo ??? [Re: Commando1] #765707
08/05/10 08:56 AM
08/05/10 08:56 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Umm...
It says Holley 830 in his sig.
Check your pump shot like Robert said. You might need a different pump cam or and adjustment of the arm.
Re: Hesitation / Bog with new combo ??? [Re: 68 Roadrunner] #765708
08/05/10 09:44 AM
08/05/10 09:44 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Along with setting initial you need to set full advance.
Re: Hesitation / Bog with new combo ??? [Re: JohnRR] #765709
08/05/10 09:48 AM
08/05/10 09:48 AM
Marcell, MN
Marcell, MN
Yeah I know. I don't have a timing light that will do it so I need to get a tape for my balancer. This hesitation is right off idle so I don't think it has anything to do with the full advance...but I could be wrong. That's why I am asking! I am no tuning expert!
Re: Hesitation / Bog with new combo ??? [Re: 68 Roadrunner] #765710
08/05/10 10:55 AM
08/05/10 10:55 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
So did it bog before the distrib swap?
Coming soon!!!!
Re: Hesitation / Bog with new combo ??? [Re: Mr.Yuck] #765711
08/05/10 11:07 AM
08/05/10 11:07 AM
Marcell, MN
Marcell, MN
Really hard to say. Like I said before it hasn't been running right since I got the motor done. I was running it with my 42 year old points distributor for the last couple weeks...so it didn't run perfect. It seems more noticeable now, but it could be because I am expecting it to run good and it doesn't.
Re: Hesitation / Bog with new combo ??? [Re: 68 Roadrunner] #765712
08/05/10 11:18 AM
08/05/10 11:18 AM
P
Paul_Fancsali Offline
P
Quit worrying about initial and set the total. The initial will be Ok in most cases for starting. Put the to near 36-38 total or more on a 383. I like 40=41
Re: Hesitation / Bog with new combo ??? [Re: ireland383] #765713
08/05/10 02:40 PM
08/05/10 02:40 PM
Commando1 Offline
Commando1  Offline
Who the hell looks at sigs to get engine specs?
Re: Hesitation / Bog with new combo ??? [Re: 68 Roadrunner] #765714
08/05/10 03:12 PM
08/05/10 03:12 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
"I put the lightest springs in the vacuum advance tonight and I will see if it makes any difference tomorrow."
Do you set the timing with the vacuum advance hooked up? Try disconnecting it completely. The vacuum advance is different than the mechanical advance, although they both advance the timing.
Read the info that came with the distributor. It may tell you how much mechanical advance it comes with, how to adjust it and whether or not it is easy to adjust without having to weld and file the slots.
Check for vacuum leaks. Check your float levels, power valve sizing and function, accelerator discharge nozzel size, jet sizes and idle A/F settings.
Are you running a PCV valve on this motor?
Re: Hesitation / Bog with new combo ??? [Re: Commando1] #765715
08/05/10 03:13 PM
08/05/10 03:13 PM
Marcell, MN
Marcell, MN
I do. I thought that is what the sig. is for. I think I may have tuned the hesitation out of the carb with the idle mixture screws. Maybe the softer springs in the dist. helped? This thing has a real hard time idling in gear. Idles at about 1200 in park and will barely idle in gear. Some guys say this is normal for Mopars???
Re: Hesitation / Bog with new combo ??? [Re: 68 Roadrunner] #765716
08/05/10 03:31 PM
08/05/10 03:31 PM
hooziewhatsit Offline
Nope, not normal
What's your initial timing at? Initial timing CAN make a difference. Advance the distributor until you get max vacuum, then retard until you lose 1"hg. You should end up around 10-15* or so. Make sure the vac advance is disconnected/plugged while doing this.
You also want heavy enough springs in the distributor that you're not into mechanical advance at idle. Otherwise sometimes you'll idle a couple hundred rpms higher than other times (BTDT).
Re: Hesitation / Bog with new combo ??? [Re: 68 Roadrunner] #765717
08/05/10 03:32 PM
08/05/10 03:32 PM
NY usa
540challenger Offline
NY usa
They have no clue what they are talking about. what does it idle at in gear???
Re: Hesitation / Bog with new combo ??? [Re: jbc426] #765718
08/05/10 03:43 PM
08/05/10 03:43 PM
Marcell, MN
Marcell, MN
Yes I am running a pcv. I check the timing with the vacuum advance disconnected.
Re: Hesitation / Bog with new combo ??? [Re: 68 Roadrunner] #765719
08/05/10 05:28 PM
08/05/10 05:28 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
here's how I do a new set up. turn your mixture screws all the way in and then back out 1 1/4 turn. start the car. Turn the idle up to 2200rpm. Set your timing in full at 38*. bring your idle back down to 1000. turn the mixture screws out until you get the best vacuum reading. Then back the idle down to 1000 (or there about) Check your initial. If it's anywhere between 12-18 you're good. RUn it back up to 2200 and check full again. NO VAC ADVANCE. Leave that unhooked. Go for a blast. If it pings drop the timing some.
Coming soon!!!!
