Page 2 of 3 1 2 3
Re: Trend pushrod failure [Re: moparniac] #765654
08/06/10 06:19 PM
08/06/10 06:19 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Though would not expect such a heavy duty pushrod to break without some type of excessive strain to be induced to it....
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Trend pushrod failure [Re: emarine01] #765655
08/07/10 11:59 AM
08/07/10 11:59 AM
U.S.
moparniac Offline OP
U.S.
See if you can look thru the spark plug hole with a good bore scope , check the exhaust relief in the piston for a contact mark, You wont always bend a valve with piston to valve contact, We broke a push rod in the middle like that pic of yours, turned out to be a guide that was too tight, I ran this engine for 2 weeks on and off at the shop and it was fine, broke the push rod on the return road after the first pass, I ended up pullin the heads cause I couldn't find the problem, I bought a good bore scope the next day
got ahold of my buddy a machinist and engine builder and he brought over a bore scope neither of us could see anything on the piston or the valve! Neat tool to have! laid a straight edge across the retainers etc. and all are straight! just trying to be as fair as possible here... we will see what Trend says and go from there now!
Mopar Performance
Re: Trend pushrod failure [Re: moparniac] #765656
08/07/10 01:55 PM
08/07/10 01:55 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Yep... its a quick way to take a variable out of the equation
Re: Trend pushrod failure [Re: emarine01] #765657
08/13/10 06:27 PM
08/13/10 06:27 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Any updates yet. Did Trend find any issues with the pushrods?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trend pushrod failure [Re: moparniac] #765658
08/13/10 06:52 PM
08/13/10 06:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That break looks like its brittle material... and it
would tend to break in the middle like it did... I
would be waiting for Trends to say something(or call
them)
Re: Trend pushrod failure [Re: MR_P_BODY] #765659
08/13/10 08:42 PM
08/13/10 08:42 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Sledgie, did ya run the engine with the offset lifters on the exhaust side, the 4 wrong ones
Re: Trend pushrod failure [Re: bigsbigelow] #765660
08/13/10 09:00 PM
08/13/10 09:00 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
That to me looks like a brittle break - could be the steel was tempered wrong
If the steel was tempered wrong, ALL of the pushrods should be replaced..
We had a similar problem a couple of years back with some Crane ductile rockers..
Defective tempering process.. With the stress the valve train takes not worth the risk..
Just my $0.00..
Re: Trend pushrod failure [Re: Sinitro] #765661
08/14/10 03:36 AM
08/14/10 03:36 AM
PA.
"Little"John
"Little"John
PA.
bump
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Trend pushrod failure [Re: moparniac] #765662
08/14/10 11:01 AM
08/14/10 11:01 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
We have never dealt with a race equipment manufactuer with better customer service than Trend. Any issues have always been resolved quickly with no issues. They are the best.
Doug
Re: Trend pushrod failure [Re: dvw] #765663
08/16/10 03:41 PM
08/16/10 03:41 PM
PA.
"Little"John
"Little"John
PA.
Just a little bump to keep it near the top. What else happened to your engine?
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Trend pushrod failure [Re: pittsburghracer] #765664
08/20/10 07:16 PM
08/20/10 07:16 PM
PA.
"Little"John
"Little"John
PA.
No word back from Trend yet? I worked in a specialty steel plant and it never took us that long to test our product. I surely hope Trend is a company we can still trust to make a great product.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Trend pushrod failure [Re: pittsburghracer] #765665
08/21/10 12:19 PM
08/21/10 12:19 PM
DANBURY CT
fury62 Offline
fury62  Offline
DANBURY CT
I have 16 passes on my 540 with trend p-rods, and no problems.they where highly recomended by best machine
Re: Trend pushrod failure [Re: pittsburghracer] #765666
08/21/10 05:35 PM
08/21/10 05:35 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
Trend checked the pushrods and ther is no problem with them. They replaced two for no charge and shipped them back. We have used Trend Pushrods in most all of our engines for years and continue to do so.
Re: Trend pushrod failure [Re: PETE@BESTMACHINE] #765667
08/21/10 08:43 PM
08/21/10 08:43 PM
PA.
"Little"John
"Little"John
PA.
Thanks Pete, Good to hear that. Its to bad people want to blame someone else before they make sure everything on there end was ok. Its not like we all haven't messed up a time or two but I guess pride enters the equation. Trend has been a trusted name in the racing world for a long time.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Trend pushrod failure [Re: moparniac] #765668
08/21/10 08:49 PM
08/21/10 08:49 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
If you roll the 2 pieces on piece of glass or surface plate, do they apprear to be bent?
You may need to dress the burr at the edge of the break.
8.30's @3400 lbs
Re: Trend pushrod failure [Re: HardcoreB] #765669
08/21/10 09:12 PM
08/21/10 09:12 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I'd start looking at the entire valvetrain before making any calls. How close do you run to spring coil bind? I'd throw an adjacent pushrod in the problem ho le and measure lift, watch trajectory during motion. Take a spring compressor (jesel-style) and see what addl. travel you have until C/B via the dial indicator. Get back with us. If you bought the parts seperately and married them together then, unfortunitly the burden of responsibility lies on you (the end builder).
Re: Trend pushrod failure [Re: emarine01] #765670
08/21/10 09:32 PM
08/21/10 09:32 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Well... its still a valid question... unless I misunderstood the long YB trash post
Re: Trend pushrod failure [Re: emarine01] #765671
08/21/10 10:29 PM
08/21/10 10:29 PM
U.S.
U.S.
Yep sure did... I missed that one all my fault and it had nothing to do with the pushrod deal ! got the right lifters in there now and im up and running again yes trend sent me a couple extra pushrods with a "disclaimer" for some reason as I know performance parts/ warranty is always a sticky subject! I knew something was up with the lifters way back when and just went by what supercomp said as I never messed with offset stuff before but it took until I emailed Bigtime a pic and the offset is supposed to be towards the exhaust lifter not away as listed in the post below! I actually had the lifters right in the block (the 4) in this old thread and the block has been clearanced for all the intake side of the lifters now for pushrod clearance... yep you posted in there also everyone will have there opinion on ALL parts Mfgs one way or another... I am up and running and going for that 9 on pump gas and radials real soon and im gonna leave it at that
https://board.moparts.org/ubbthreads/show...rue#Post5782164
Mopar Performance
Re: Trend pushrod failure [Re: moparniac] #765672
08/21/10 10:39 PM
08/21/10 10:39 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I still have never seen one snap in the middle like that. I used to run 3/8ths .135 wall manleys and never broke one.
I now have 7/16ths .165 walls and picked up 700 rpm. So my old ones were flexing.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Trend pushrod failure [Re: moparniac] #765673
08/22/10 02:23 PM
08/22/10 02:23 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
...just went by what supercomp said as I never messed with offset stuff before >>>BUT<<< it took until I emailed Bigtime a pic and the offset is supposed to be towards the exhaust lifter not away as listed in the post below!
I knew it!!! It was Supercomp's fault all along for not making certain you understood what he told you. I doubt he'll let you throw him under the bus again. I will give big props to Bigtime for being patient and helpful. I doubt this post will change how you operate but, as a business I personally would not do business with you based on how you've been posting during the whole process of your build. IMO you have bashed BEST, and Trend and then backpeddled. Yet the truth is not out. Noone, including you, knows what the real reason of the failure is because you have not taken the correct steps to validate measurements during building. I really hope you take this constructively and we move on because it appears you have built a cool car there. People here have been willing to help with good advise etc. so, you can do it yourself, and save or have some satisfaction.
Page 2 of 3 1 2 3
