Re: SB Stroker timming?
[Re: Voluster]
#764447
08/03/10 01:38 PM
08/03/10 01:38 PM
Posts: 7,506 Az
Crizila
Az
Last time I was out with my 408 I ran 31 degrees total. I've run as high as 38, but it seems to like 31 best so far. Similar set up to yours - running ported iron rams 246 / 250 @ .050 with 108LSA. Running a tight quench @ about .035".
Fastest 300
[Re: 74_360_Cuda]
#764450
08/03/10 05:32 PM
08/03/10 05:32 PM
Posts: 3,695 nc
emarine01
nc
Lots of variables here, head shape, compression fuels, cam timing , air temps, even a dyno session wont tell you whats best on the track, that's what test and tune is all about, I have run from 29 to 36 on my w5 rig and seems that 34 works for most conditions, I not saying its the best but it works
