68 dart gt #763968
08/02/10 10:34 PM
08/02/10 10:34 PM
granite bay ca
dodgeguy7714 Offline OP
granite bay ca
so i want to put a 5.9 magnum in this dart using all the electornics fuel injection system.only thing is i dont want to cut up fabricate stuff to put a 518 (4 speed auto )in it.so can i notch the old school 727 bell housing mount the crank sensor and use the magnum flex plate .pretty sure i can do this but how accurate would i need to be on location of crank sensor. this is real budget here so is main reason not just running manifold and carb dont have either
Re: 68 dart gt [Re: dodgeguy7714] #763969
08/03/10 12:35 AM
08/03/10 12:35 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
You would need a computer for a manual trans car so it doesnt care about the electronic controls for the transmission.
yes, you can cut a notch in the bellhousing and there were indeed 727 transmissions in early 90s vans with the efi magnum so there is a factory flexplate that will work for that application. I want to say one from a 92-94 van maybe? It would be wise to see if you could find one in a junkyard somewhere and look at what it has. I do know though for sure that the vans used a magnum with a 727 even if for a short time.
The location of the crank sensor is very important, but since it's actually bolted to the block you would only have to make sure the slot cut into the bellhousing is where it needs to be.
If you found one of the 727 cases that was originally set up this way you would be ahead of the game. Heck you could take the computer and everything and just swap it all in as is.
The efi magnum engine in a dart would be a lot of fun since the magnum has real good low end torque. It would be perfect for a fun driver, and with those SCT tune things, you could do some nice changes to the cam and heads too for even more power while retaining the factory efi too.
I am sure there are other people with more info for you. I'm only trying to kickstart this since I see no one has replied. Good luck!
Re: 68 dart gt [Re: POS Dakota] #763970
08/03/10 07:39 PM
08/03/10 07:39 PM
granite bay ca
granite bay ca
thanks i aprciate it hmmm the flex plate i have is off the 2002 but the cpomputer and all the other is off a 95 dodge ram wonder if im still messed up and need to get that flex plate
