NEED HELP..440 REAR MAIN LEAK
#763317
08/02/10 07:40 AM
08/02/10 07:40 AM
Posts: 289 Lowes
steve660
Lowes
440 block, Eagle crank, been together 3 years. Tore engine down, had mains turned .010, and align honed and put back together with same rear main seal. Primed engine on stand,(80 psi)& rear seal leaks, not the sides,just the seal. doesn't leak immediatley maybe a minute after i stop priming it, it will start dripping. I'm using a standard seal from Mancini Racing&10w-30 conventional oil.The seal is installed correctly, the lip facing inward. Could it be from having it align honed??
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
Re: NEED HELP..440 REAR MAIN LEAK
[Re: JohnRR]
#763319
08/02/10 10:35 AM
08/02/10 10:35 AM
Posts: 289 Lowes
steve660
Lowes
HAD LESS THAN 100 PASSES ON IT. didn't leak before.
[Re: steve660]
#763320
08/02/10 11:24 AM
08/02/10 11:24 AM
Posts: 11,080 Berlin, N.J.
abodyjoe
Berlin, N.J.
All that time and money and you cheaped out on the rear main seal? ??
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: abodyjoe]
#763322
08/02/10 04:01 PM
08/02/10 04:01 PM
Posts: 289 Lowes
steve660
Lowes
YEAH I CHEAPED OUT... IT WAS GOOD WHEN I TORE IT DOWN. NO IDEAS HUH....????
[Re: RobR]
#763324
08/02/10 06:28 PM
08/02/10 06:28 PM
Posts: 289 Lowes
steve660
Lowes
Thanks man, now that makes sense!!! I guess if i hadn't cheaped out, it would have been ok. Learn something new everyday.
[Re: roadhazard]
#763328
08/03/10 01:04 PM
08/03/10 01:04 PM
Posts: 289 Lowes
steve660
Lowes
Thanks roadhazard, I remembered seeing that thread before but couldn't find it. Lots of good info there!
[Re: Stanton]
#763330
08/03/10 02:34 PM
08/03/10 02:34 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Hmmm ... those instructions are word-for-word what comes with the 440Source retainer and seals. Could it be that not all their stuff comes from China after all ?!?! That would certainly be a disappointment to many bashers!
You are ASSuMEing alot in that statement , which is pretty much standard operating procedure for a source
