69 Roadrunner Wheel Covers
#763163
08/01/10 11:24 PM
08/01/10 11:24 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Got a Broadcast Sheet out of a 69 Roadrunner for a friend
Looking for info on Wheels and Tires
Coded for W25 Wheels - Wheels H.D. Stamped T85 - F 70 X 14 RSW
W11 Wheel Covers - Deluxe Class I
Bottom Line - What should these look like , especially the Wheel Covers
Pictures or any info on the Tires and Wheel Covers
Thanx Scott
By the way - This is a Factory 383 / 4 Speed / A31 Axle Package / N96 Air Grabber Car that he just picked up - #s Matching Drivetrain
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
Re: 69 Roadrunner Wheel Covers
[Re: bee1971]
#763164
08/01/10 11:38 PM
08/01/10 11:38 PM
bee1971
Sobieski Wi
Forgot to add under Wheel Looks like 16 - X9 ?
The box next to it - Has a hole/missing exactly in that spot under wheel cover - Go figure
Color of car is 97
Thanx Scott
[Re: 3hundred]
#763168
08/02/10 12:18 AM
08/02/10 12:18 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
W25 - Wheels will be 14x5.5" & (in your case - X9) painted "black" T85 - Tires will be F70-14 "red streak" Goodyear Polyglas W11 - "deluxe wheel covers" - a $21.30 OPTION Satellite - Wheel covers will be #2823010, if any # is visible on b'cast it will be 10. Road Runner & GTX - Wheel covers will be #2881758, if any # is visible on b'cast it will be 58.
[Re: 6bblgt]
#763169
08/02/10 02:50 AM
08/02/10 02:50 AM
Posts: 21,511 N.E. OHIO, USA
A12
N.E. OHIO, USA
Wheels will be 14x5.5" & painted "black" Tires will be F70-14 "red streak" Goodyear Polyglas Wheel covers will be #2832010, if any # is visible on b'cast it will be 10.
Dan and Scott, FWIW I ordered my first ('69) road runner back in the Spring of '69 and it came with the "Sport" wheel covers as shown above and here:
All five wheels including the spare were black and not body color. Over the years I've seen a lot more rr's with the "Sport" wheel covers than the "deluxe" covers FWIW.
MikeR
[Re: A12]
#763171
08/02/10 04:20 AM
08/02/10 04:20 AM
6bblgt
Las Vegas, NV
Good call Mike! I always thought there were three levels of available "wheel covers" for the '69 Plymouth b-body line. My mistake. I have Satellite b'casts with W11 & the 10 wheel cover. Every Road Runner & GTX b'cast sheet I have that has W11 & W25 has the 58 wheel cover & wheel. Window stickers refer to it as the same OPTIONAL $21.30 "deluxe" wheel cover. Here's the b-body #2881758 wheel cover:
[Re: 6bblgt]
#763172
08/02/10 04:27 AM
08/02/10 04:27 AM
6bblgt
Las Vegas, NV
Anybody have a '69 Sport Satellite with W11 "deluxe" wheel covers? What's on the b'cast sheet? Not to be confused with the c-body wheel cover with a different paint job. #2881781
[Re: 6bblgt]
#763173
08/02/10 11:19 AM
08/02/10 11:19 AM
bee1971
Sobieski Wi
You guys are awesome
THANX !!!!
Like mentioned earlier , the part # is not visible up top on the Broadcast Sheet for the Wheel Covers - There is a hole in the Broadcast Sheet exactly in that spot for the part # - Sheet is in great shape except for a few small holes
Thanx Again !!!!
Scott
