Re: Who here knows old TRW piston stuff...
[Re: dizuster]
#762910
08/01/10 04:04 PM
08/01/10 04:04 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
I know a L2316F is a forged 10.5 340 replacement piston...
is the F for Forged?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#762911
08/01/10 04:20 PM
08/01/10 04:20 PM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
This is true as i had this piston at one time,semi domed flat top w/2 valve reliefs
[Re: 70AARcuda]
#762914
08/01/10 04:39 PM
08/01/10 04:39 PM
Posts: 3,639 Oakland, MI
dizuster
Oakland, MI
And that's the problem. Every forged piston I can find has both an "L" and a "2"
I've yet to see a "L" and a "3" except for this set...
[Re: dizuster]
#762916
08/01/10 11:46 PM
08/01/10 11:46 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
As far as I know, any TRW piston part number (no matter how old), if it STARTS with an "L" that they are forged not cast.
From what I know the actual first digit in the part number has NOTHING to do with forged or cast. Someone told me that if it's a "2" it's forged, but if it's a "3" it's cast... I don't believe that's true?
Does anyone know for sure? I'm trying to ID a set of pistons but I can't guarantee they are what I need.
Is it easy to tell if an OLD TRW is a forged or cast piston?
I remember being told "that all TRW Part Numbers Starting with "H" are Hypereutectic pistons and Part Numbers Starting with "L" are Forged"...
Rickster
[Re: dizuster]
#762918
08/02/10 03:13 PM
08/02/10 03:13 PM
Posts: 43,725 Bend,OR USA
Cab_Burge
I looked in my old TRW catalog, no innformation on that part number, your pistons are to new My catalog is really old, I did try googling that part number and had no luck there either Sorry I couldn't help more.
[Re: John_Kunkel]
#762922
08/05/10 12:41 PM
08/05/10 12:41 PM
Posts: 885 south louisiana
lowell66dart
south louisiana
Part numbers in the below charts with a H as the first digit are hypereutectic pistons, if the first digit is a L they are are forged pistons. Under Pin Type, P indicates the piston will work with a press pin type connecting rod, F means the piston will work with a floating pin connecting rod. If you see P or F it means the piston can be used with either type of connecting rod. FT under the top shape column means Flat Top piston, if it also has valve reliefs the number of reliefs will be listed also
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
