mopar 440 motor plate and alternator question #762840
08/01/10 12:52 PM
08/01/10 12:52 PM
Manteno, IL
dakota27 Offline OP
dakota27  Offline OP
Manteno, IL
i just got my 540 stroker motor done and ran into a problem. im putting it in a 97 dakota and using a front and rear motor plate but the alternator does not fit in the stock location with the front motor plate. is there a kit i can buy to move the alternator somewhere else and keep it in line with the crank and water pump pulley? or do i have to fab up a bracket for it?
Re: mopar 440 motor plate and alternator question [Re: dakota27] #762841
08/01/10 01:03 PM
08/01/10 01:03 PM
Auburn, Indiana
The Duster Offline
The Duster  Offline
Auburn, Indiana
Take a look here and see if this helps.
https://board.moparts.org/ubbthreads/show...e=1&fpart=1
Re: mopar 440 motor plate and alternator question [Re: dakota27] #762842
08/01/10 01:07 PM
08/01/10 01:07 PM
Southern IL.
jafr Offline
jafr  Offline
Southern IL.
I used a east coast kit and bolted it directly to the motor plate. I have the alternator on one side and my rons injection pump on the other side of the motor plate. Had to drill the pulley to mount to the mopar balancer and trim the spacers some.
Re: mopar 440 motor plate and alternator question [Re: The Duster] #762843
08/01/10 01:38 PM
08/01/10 01:38 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
home of the
Sox and Martin Hemi Duster
Re: mopar 440 motor plate and alternator question [Re: dakota27] #762844
08/01/10 05:30 PM
08/01/10 05:30 PM
AndyF Offline
AndyF  Offline
I make a motor plate kit that is designed to work with my other products. It may or may not work with the stuff you have on hand.
Re: mopar 440 motor plate and alternator question [Re: AndyF] #762845
08/01/10 05:36 PM
08/01/10 05:36 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Andy, Does your motorplate / low mount alternator kit work with a traditional, stock style crank driven water pump? I looked on your site, but didn't see any examples of such.
- Any examples you could show would be helpful, as we are ready to purchase something.
