Aluminum rod clearance #762790
08/01/10 01:07 PM
08/01/10 01:07 PM
Central Wi.
1965wedge Offline OP
Central Wi.
When using aluminum rods what are the required clearances from the piston to head,piston to valve and rod side clearance min/max?
Re: Aluminum rod clearance [Re: 1965wedge] #762791
08/01/10 01:41 PM
08/01/10 01:41 PM
Contact the rod company your using and use thier recommendations I think BME on there forged rods recommended .055 piston to anything clearances and .030 rod side clearance on a normaly asperated (no power adders)drag motor. More side clearances is better than not quite enough I had a BME forged aluminum drag motor that had .050+ side clearances, it ran fine and had no indictaions of problrems when inspected after multiple dyno pulls and races
Re: Aluminum rod clearance [Re: Cab_Burge] #762792
08/01/10 01:44 PM
08/01/10 01:44 PM
Central Wi.
Central Wi.
Thanks for the info.
Re: Aluminum rod clearance [Re: 1965wedge] #762793
08/01/10 01:47 PM
08/01/10 01:47 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Many rod manufacturers make their aluminum rods about .025 shorter to compensate for expansion. So ask your rod supplier what the actual C-C distance is.
Re: Aluminum rod clearance [Re: Cab_Burge] #762794
08/01/10 08:09 PM
08/01/10 08:09 PM
NC
440Jim Offline
440Jim  Offline
NC
I think BME on there forged rods recommended .055 piston to anything clearances ...
I don't think you mean to piston wall clearance, do you?
Re: Aluminum rod clearance [Re: 440Jim] #762795
08/01/10 08:49 PM
08/01/10 08:49 PM
Arizona
Chris'sBarracuda Offline
Arizona
I was always told that the length of the rod added into the equation.
I have a 6.535 rod and therefore have .065 piston to head clearance. A 7.100 rod would need .070..
Don't know if this is real world, but has worked for me. I have used aluminum rods for over 20 years in every engine I have.. Zero failures.. Knock on wood..
Chris..
Re: Aluminum rod clearance [Re: Chris'sBarracuda] #762796
08/01/10 09:34 PM
08/01/10 09:34 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We run a 6.123 BME @ .058, BME recommended .060
Re: Aluminum rod clearance [Re: 440Jim] #762797
08/01/10 11:15 PM
08/01/10 11:15 PM
your absolutly correct on that. I should have said piston to head or valve clearances, not anything else
