Can anyone help me with the proper diagram of a fuel line/ fuel filter installation from the pump to the carb. I have a 71 383 holley four barrel the original carb was replaced with an aftermarket one( edelbrock) the original fuel lines were gone. I now have the proper carb but all that anyone sells is a one piece fuel line. Is there a rubber hose from the pump to the filter then the steel line to the carb? I know to some of you this may sound screwed up but I am from the small block crowd that has steel from the pump to the filter and then steel from the filter to the carb. Thanks in advance for any help.
