Page 1 of 3 1 2 3
Track Report E-85, very pleased #762471
08/01/10 01:28 AM
08/01/10 01:28 AM
Columbus, Ohio
wheelsup68dart Offline OP
Columbus, Ohio
It was a long day for sure, but all I can say is there should be a large change over to E-85 My carb went on this morning, I flushed the lines, installed, set float level and success! the car fired right up, small idle screw adjustment and car idled beautiful. Got to the track and unloaded with a 6.09 @ 111.0 I woulda predicted a 6.10-6.08 on gas with similar air. Made a squirter change from 37 to 42 cause the car seemed lazy at the hit to 2 step and changed high speed air bleeds to 28 from 27. Second pass 6.06. Bumped jetting from 94 square to 95/96. 3rd pass 6.06. Car got staged a bit deep so I woulda considered it a 6.05. No changes to car for 4th time run, and 6.05 again. On dash for cash I put a 6.06 on car and went 6.058. 1st rnd of quick 32 6.05 dial and red light 6.052. 1st rnd of super pro 6.05 dial and on brakes at stripe 6.061 gave up stripe by .0062 and woulda been 6.051. Buy back for super pro 6.05 dial 6.052 pass after opponent red light. 3rd round 6.05 dial and track had gone away at starting line 6.07. Consistency has definetly been found and it is nice to not have to cool car when it gets back to pits. I was leaving line at 170 degrees finish line at 178, and by time I would ease back to pit spot I was already back to 174 I made plenty of passes on the car and estimate that it cost me about $14.00 in fuel.
Needless to say I am quite pleased with the initial results and can't wait to see the 1/4 mile performance and continue to fine tune this thing.
Re: Track Report E-85, very pleased [Re: wheelsup68dart] #762472
08/01/10 01:45 AM
08/01/10 01:45 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
This really validates my decision to run the stuff.
Very nice to see.
Now.........if I could just get all my machine work done and make some laps.
That is a model of consistency right there.
Great job.
Re: Track Report E-85, very pleased [Re: tubtar] #762473
08/01/10 01:59 AM
08/01/10 01:59 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
over that period how much did the DA change
home of the
Sox and Martin Hemi Duster
Re: Track Report E-85, very pleased [Re: HEMIFRED] #762474
08/01/10 02:01 AM
08/01/10 02:01 AM
Columbus, Ohio
Columbus, Ohio
My PerformAire box has been down so I could not answer that, but was hearing that the changes throughout the day were not significant.
Re: Track Report E-85, very pleased [Re: wheelsup68dart] #762475
08/01/10 03:06 AM
08/01/10 03:06 AM
PA
ajcasini Offline
ajcasini  Offline
PA
Lonnie thats great to hear. E85 really is great stuff. My car tonight ran as fast as 11.118 and slow pass was 11.151. .033 change from 3PM to 1AM. DA was at 3300 to start the day dipped to 2400 then back up to 3000 for the final.
I have done a few carbs for local guys at PRP and they are in love too.
I bet with a little fine tuning we can have the car in the 5.90's.
Re: Track Report E-85, very pleased [Re: ajcasini] #762476
08/01/10 04:25 AM
08/01/10 04:25 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I WANTD TO USE ANY NUMBERS TO COMPARE WITH MY ONLINE CALCULATOR CHART
http://www.dragtimes.com/da-density-alti...et+Weather+Data
home of the
Re: Track Report E-85, very pleased [Re: wheelsup68dart] #762477
08/01/10 09:32 AM
08/01/10 09:32 AM
NC
440Jim Offline
440Jim  Offline
NC
Glad to hear it worked out for you.
... but all I can say is there should be a large change over to E-85
<after jetting>
6.05
6.058
6.052
6.052
Very nice. Basically 6.05 all day after jetting. I take it that last 6.07 was due to a poor 60ft.
I agree this is a great hot rod fuel. I say it is between gas and methanol (alky). Typically quicker than gas, but not quite like alky, cooler than gas, but not as cool as alky (but less warm-up time and easier cold weather starting); less corrosive than alky too. But E85 is definitely the cheapest total fuel cost per day for a high compression engine.
I love this fuel too. Bring on the ethanol plants and filling stations, grown and distilled in America.
Re: Track Report E-85, very pleased [Re: 440Jim] #762478
08/01/10 09:39 AM
08/01/10 09:39 AM
NC
440Jim Offline
440Jim  Offline
NC
On Saturday we had a double header race. My first pass (time trial) was at 10:53am and my last was at 9:06pm before the rain came. My car ran between 5.911 and 5.937 all day and the slower runs were after I added 20 pounds ballast, so I should really correct them 0.02 seconds (5.917)
Weather varied from 92ºF, 20%RH to 76ºF, 50% RH.
Not every day is this consistant, but the fuel is very consistant.
Re: Track Report E-85, very pleased [Re: wheelsup68dart] #762479
08/01/10 10:42 AM
08/01/10 10:42 AM
NC
440Jim Offline
440Jim  Offline
NC
This is my fuel cost comparison for a typical 5 passes down the 1/4 mile plus warm up time/fuel.
My 511 drinks some fuel, and a smaller motor should use less.
110 Gas: (5 passes x 0.7 gal/pass + 0.5 warmup) x $7.75/gallon = $31
Methanol:(5 passes x 1.5 gal/pass + 1.0 warmup) x $2.70/gallon = $23
Pump E85:(5 passes x 1.0 gal/pass + 0.5 warmup) x $2.55/gallon = $14
On a cool day, I have seen guys burning lots of methanol to warm up their motors, even between passes. So that 1.0 gallons is minimum for methanol, IMO. And I have seen reports around the country selling E85 for $1.99/gallon. But it is more expensive in Maryland.
http://e85prices.com/
Cheap hot rod fuel for high compression engines. Mine is 13.5 CR.
So if you make 150 passes per year, that should save at least $500/year compared to race gas.
Re: Track Report E-85, very pleased [Re: 440Jim] #762480
08/01/10 10:48 AM
08/01/10 10:48 AM
Columbus, Ohio
Columbus, Ohio
I am 13.5 to 1 also Jim. Just cannot believe there was no more to the switch than that. Our E-85 is 2.29 a gallon right now. I did not find a drop sheet at the station I stopped at, but the sticker at pump said minimum 85% ethanol so I would assume that if audited by department of weights and measures they would be honest here. I cannot wait to see what the 1/4 mile results are, I would suspect they will be right in line with the 1/8th but my 6.05's yesterday woulda been 9.59's in the heat and I like that idea.
Re: Track Report E-85, very pleased [Re: wheelsup68dart] #762481
08/01/10 10:58 AM
08/01/10 10:58 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
I don't have much to add but i can't wait to make the change over next year. love to here these good reports
Re: Track Report E-85, very pleased [Re: wheelsup68dart] #762482
08/01/10 11:00 AM
08/01/10 11:00 AM
NC
440Jim Offline
440Jim  Offline
NC
Here is a new sig picture for you! LOL
Re: Track Report E-85, very pleased [Re: 440Jim] #762483
08/01/10 12:33 PM
08/01/10 12:33 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Great results!
I'm thinking about converting one or all of my toys to E85, there's a station not too far away.
IIRC E85 cannot be sold profitably without the .50/gallon government subsidy, I suppose when they figure out how to run the John Deere harvesting equipment on E85 instaed of Deisel they'll really be on to something!!
also related....here in NC it is nearly impossibnle to find a gas station that doesn't pump "up to 10%" ethanol in the normal blend. What's "bad" about that is it's a cheap octane spike for gas but it's btu output is likely to somewhat diminish the MPG of conventional fueled vehicles....so ironically in this green environment (when you consider the 'macro' picture) this is assisting the big oil companies to sell a lot more Gas!
Is there any "definative" write up on a start to finish conversion? What else inthe fuel system needs converting?
WIZE
In Car:
Re: Track Report E-85, very pleased [Re: wheelsup68dart] #762484
08/01/10 12:36 PM
08/01/10 12:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s great. I don`t have access to E-85 locally and if I did, I`d definately be trying it out.
Re: Track Report E-85, very pleased [Re: Thumperdart] #762485
08/01/10 01:51 PM
08/01/10 01:51 PM
Newark, OH
springers340dart Offline
Newark, OH
that thing was running great bro!!! according my the air gauge i was using it was between 3570 and 3800 DA.
Re: Track Report E-85, very pleased [Re: springers340dart] #762486
08/01/10 06:23 PM
08/01/10 06:23 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
all this sounds great but can anyone tell me about the maint part of it like how often on oil changes, fuel lines what pump and presure you need what size fuel lines etc
thanks
Re: Track Report E-85, very pleased [Re: springers340dart] #762487
08/01/10 06:27 PM
08/01/10 06:27 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
How much of an ordeal is it to change a gas carb to E-85?
Re: Track Report E-85, very pleased [Re: supercomp] #762488
08/01/10 07:07 PM
08/01/10 07:07 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Maintenance is the same as gas. Maybe even less because the E85 burns so clean. When I tore my engine down at the end of last season the combustion chamber was amazingly clean. After 500 runs it looked almost new. I don't think its any harder on the fuel pump and lines than racing gas. My roadster has a Mallory 110 and the Dart has a Jegs billet pump and both have worked fine on E85.
The only difference you may notice is a bit milk on the top of the valve covers. Its easily remedied by letting the enigine warm to 200 before parking for the night then pull the breathers or oil cap.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Track Report E-85, very pleased [Re: 69dart] #762489
08/01/10 07:28 PM
08/01/10 07:28 PM
Hemiroid Offline
Hemiroid  Offline
E-85 is great for a race car, but I wouldn't consider it street friendly. Getting 3 mpg requires a mighty big cell/tank to get anywhere. That and if you need to find fuel to add while street driving finding corn juice could be a problem.
Re: Track Report E-85, very pleased [Re: Thumperdart] #762490
08/01/10 07:31 PM
08/01/10 07:31 PM
Q
Quicktree Offline
Quicktree  Offline
Q
same here would save a bunch on race fuel.
Page 1 of 3 1 2 3
