Re: 413 motorhome engine
[Re: bigD]
#76245
06/20/08 12:21 AM
06/20/08 12:21 AM
Posts: 2,001 s. e. pa.
calrobb2000
s. e. pa.
hi 413 fine as they are or turn into a 426 by just boring o.s. i always liked my 413 ,car is long gone but engine is in the garage waiting to be reserected !
[Re: dave571]
#76247
06/20/08 02:59 AM
06/20/08 02:59 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
my old 72 Winnie had the 413 ind engine. it was a 6 bolt crank, but as stated above it has huge heads, funky water pump assy and a monster intake. it was a torque monster. If your buddy goes for it the only useable parts for a car app would be the block, crank(same as 440)and rods. and maybe pistons if he wants a low comp engine.... I can see a 871 blower bolted on top of one...
I am truckless..
[Re: 340SHORTY]
#76248
06/20/08 10:49 AM
06/20/08 10:49 AM
dogdays
But not all motorhome 413s had the weird heads, water pumps and manifolds. Look at it this way: At 750 lb it is worth $82.50 as scrap. The transmission has heavy-duty guts although the tailshaft and housing will have to be changed to one from a car.
I say go get it. A man can never have too much cast iron aging in the back yard!
R.
[Re: dogdays]
#76249
06/20/08 02:38 PM
06/20/08 02:38 PM
Posts: 74 Haysville, Kansas
rdrmod6
Haysville, Kansas
I nought a 413 motorhome engine from a motorhome a while back. It is supposed to have around 33,000 miles on itand I needed a runnung bigblock so I could move the car around under its own power. When I picked it up I was supprised at what I got. It has unique cylinder heads, exaust manifolds, distributor, oil pump drive, camshaft, and a gear drive for the cam. the dampner is also different. It also has low compression pistions, on the positive side it has a steel crank with a 6 bolt flange. as soon as I am done with the car I intend on using this for a 426, but until then I have a large stack of iron left over from the motorhome specific parts. If you have the room to store it why not? they sure are not making them anymore.
