any tricks to reinstalling door panels? #762371
07/31/10 10:34 PM
07/31/10 10:34 PM
Keizer, Oregon
Dadrules Offline OP
Dadrules  Offline OP
Keizer, Oregon
finally getting to finishing the interior in our 65 Barracuda. I've never found a good way to reinstall the door panels, I seem to at least bend some of the clips or tear the cardboard backing on the panel. is there a way to reinforce the backing board around the holes where the clips go? and any other method than eyeballing the clips and the holes in the doors and crossing my fingers and smacking the panel at each clip? thanks for any help...
Re: any tricks to reinstalling door panels? [Re: Dadrules] #762372
07/31/10 11:45 PM
07/31/10 11:45 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
On my last car I left the clips out and used velcro strips instead. Works just fine, doesn't leave lumps in the panels, and is way easier to remove.
Re: any tricks to reinstalling door panels? [Re: Neil] #762373
08/01/10 02:06 AM
08/01/10 02:06 AM
Keizer, Oregon
Dadrules Offline OP
Dadrules  Offline OP
Keizer, Oregon
that is a great idea! my wife uses the stuff all the time and it never crossed my mind. do you use the stuff that's got adhesive on the back or did you use mechanical fasteners for the part attached to the steel on the door?
Re: any tricks to reinstalling door panels? [Re: Dadrules] #762374
08/01/10 10:16 AM
08/01/10 10:16 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Some of the new adhesive backed velcro strips are pretty darn strong... I'd try that route before committing to a custom fastener...
