Front Brake Drum Removal #762339
07/31/10 08:52 PM
07/31/10 08:52 PM
Out in Left Field, NY
bobs66440 Offline OP
Does anyone have an easy method for separating the front brake drum from the hub? I was able to get one but the other is stubborn.
Thanks, Bob
Re: Front Brake Drum Removal [Re: bobs66440] #762340
07/31/10 10:44 PM
07/31/10 10:44 PM
You'd want to have your machine shop use their swedge cutter tool to remove the "swedge" at the base of the stud that holds it to the drum then it'll easily press out
Re: Front Brake Drum Removal [Re: bobs66440] #762341
07/31/10 10:45 PM
07/31/10 10:45 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Hello! Try dropping the drum assembly down flat on the floor from about waist high. Or, try a big "Dead-blow" hammer, or try a block of wood with a BFH...most work! Jeff
Re: Front Brake Drum Removal [Re: 1969RR] #762342
08/02/10 10:28 AM
08/02/10 10:28 AM
Thanks!
Re: Front Brake Drum Removal [Re: bobs66440] #762343
08/02/10 12:15 PM
08/02/10 12:15 PM
Cab_Burge Online work
Cab_Burge  Online Work
Be very careful on removing the drum if you want to save it, it is very easy to ruin them by not removing the swedges first I use a deep well socket under the wheel stud and a lug nut on the stud and then drive them out, I don't own or know anyone with a swedge cutter, maybe I should buy one now that those old drums are getting harder to find the left sides on the early cars with left hand threads on the driver sides seem to be the worst ones to get off
Re: Front Brake Drum Removal [Re: Cab_Burge] #762344
08/02/10 01:46 PM
08/02/10 01:46 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Most good machine shops have the cutter.We also had the tool to swedge the drums back on at work before.Ive seen the hubs bend also because people tried to hammer the studs out.Droppimg the drum I doubt very much would get the hub to pop off unless they were removed before.Rocky
Chrysler Firepower
