A body: BB v SB #762259
07/31/10 06:50 PM
07/31/10 06:50 PM
Ohio, USA
Donny Offline OP
Donny  Offline OP
Ohio, USA
My dilemma: New proud owner of 69 Dart (with 318) & I want this to be a street/strip car, mostly street but when/if I go to track (maybe half dozen times a summer) would like it to be a mid 11 to low 11 car, but we all now how that changes....
BTW this is not a #s matching car, so mods and slight cut up is no problem.
I have a mildly done 440, .509, M1, stock bottom end, nice set of cast iron heads (done by Nick) IIRC currently a 9:1 motor that I would like to bump up the compression on and maybe go up a notch or two in cams (this 440 powered a 3850lb 69 B body to 12.50's on street tires and very average suspension at best).
Question is what would be the better approach with my goal as stated above, continue improving on the 440 I already own (how much $ and upgrades I would need not sure) or build up a SB (maybe something like a new 360 stroker etc....).
Looking for opinions on the pros v cons, I'm sure some consider this one of those never ending debates. Weight, money, fit etc...
Fire away.
Re: A body: BB v SB [Re: Donny] #762260
07/31/10 07:05 PM
07/31/10 07:05 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
A big block is a fairly easy swap, plus you've already got one. For street handling, the extra weight is much less of an issue with today's parts and tires than it was in the 1960s.
Re: A body: BB v SB [Re: Jim_Lusk] #762261
07/31/10 07:36 PM
07/31/10 07:36 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
If you like power steering or changing your spark plugs you'll want to stay small block. The extra torque is not really needed either.
I have a small block with power steering & TTI headers and even its a tight fit. Otherwise its very easy to work on. My car runs very well with even a mild smallblock.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: A body: BB v SB [Re: Donny] #762262
07/31/10 07:43 PM
07/31/10 07:43 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
Use your 440. I have had a few of the A-bodies with big blocks in them since 1977. It is fairly easy to get into the 11 second bracket. You will need to do a little suspension work and Tire or Slick selection.
Have fun
Re: A body: BB v SB [Re: joewhite440] #762263
07/31/10 08:40 PM
07/31/10 08:40 PM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
My A Body with RB has no issues with changing plugs.
At one time I ran PS, too, but with B body exhaust manifolds.
Since you own the 440 I don't see the hard decision here.
Re: A body: BB v SB [Re: joewhite440] #762264
07/31/10 08:46 PM
07/31/10 08:46 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Like said, you already have the BB, if it ran 12.5s in the B body, it should easily run high 11s in the A body as it sits, The .509 is a good cam once tuned currectly, they like at least a true 9.7.1 or better compression, at least 3.91s & a converter thats around 36-3800, there are better cams out there, but you can run 10s with that one. With a few changes & tuneing, with sticky tires you should see mid 11s is not better fairly easy in the Duster.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: A body: BB v SB [Re: Donny] #762265
07/31/10 08:48 PM
07/31/10 08:48 PM
Go BB even if you didn't have one yet (& you do!). Go here for even more info. www.bigblockdart.com and www.forabodiesonly.com
Re: A body: BB v SB [Re: GregCon] #762266
07/31/10 08:53 PM
07/31/10 08:53 PM
Ohio, USA
Donny Offline OP
Donny  Offline OP
Ohio, USA
I guess my thought process is if I need to dump more money into the 440 maybe it would be best to just drop a little more and start w/a brand new SB, save some lbs and space and work?
With all things being equal I'm guessing 600HP is the number to get to, expecting the suspension to work like most (meaning well but not 100% as desired).
Maybe I am underestimating the 440 I have or what kind of ET it would produce with a little more work in said Dart?
Re: A body: BB v SB [Re: joedust451] #762267
07/31/10 08:56 PM
07/31/10 08:56 PM
Ohio, USA
Donny Offline OP
Donny  Offline OP
Ohio, USA
The one thing about my 440 is that it's a low compression motor right now, bumping that up to 10 could do wonders itself I suppose. Did have a very low stall in the B body, but did run it with 4.10s (the gears of which I still own).
Re: A body: BB v SB [Re: Donny] #762268
07/31/10 09:02 PM
07/31/10 09:02 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I'd drop it in as is and baseline it. The motor is likely plenty for what you want. The rest will come from suspension and launch techniques.
Re: A body: BB v SB [Re: Donny] #762269
07/31/10 09:34 PM
07/31/10 09:34 PM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
Big Block Dart
Re: A body: BB v SB [Re: Jim_Lusk] #762270
07/31/10 09:42 PM
07/31/10 09:42 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
Re: A body: BB v SB [Re: bp27] #762271
07/31/10 11:15 PM
07/31/10 11:15 PM
IN
ahy Offline
ahy  Offline
IN
A different perspective... a mild low compression BB in an A body is the worst of both worlds. Heavy on the front with less power than a decent SB stroker.
I think your setup would do really do well with a SB stroker. Start with a JY 5.9 Magnum core, add a 4" crank kit, add RHS iron or Elelbrock aluminum heads and you would have a pretty easy 400 - 500 HP depending on how "streetable" you want it and budget.
Re: A body: BB v SB [Re: ahy] #762272
07/31/10 11:36 PM
07/31/10 11:36 PM
Ohio, USA
Donny Offline OP
Donny  Offline OP
Ohio, USA
The only response I have to that is I am fairly confident my current 440 set up is real close to 500hp, thanks for the added perspective though.
Re: A body: BB v SB [Re: Donny] #762273
07/31/10 11:40 PM
07/31/10 11:40 PM
Dont forget the subframe connectors/roll cage
Re: A body: BB v SB [Re: RapidRobert] #762274
08/01/10 01:30 AM
08/01/10 01:30 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
ahy, the added weight on the front is really not a big deal with parts that are available today. Consider our succesful autocross 67 383/4sp Barracuda and all the street miles we have put on the 440/4sp setup that is in my son's 67 Dart convertible. With ALL stock components that Dart will outhandle most stock musclecars and certainly does NOT feel noseheavy.
And before you say I have nothing to compare it to. It handles BETTER than our completely stock 68 340 GTS convertible.
But, granted we are talking more about drag racing and straight line performance for this discussion, but the old myth about big block A-bodies and poor handling has been put to rest a long time ago.
Re: A body: BB v SB [Re: Jim_Lusk] #762275
08/01/10 01:44 AM
08/01/10 01:44 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
So true!
Re: A body: BB v SB [Re: Jim_Lusk] #762276
08/01/10 01:49 AM
08/01/10 01:49 AM
MNobody Offline
MNobody  Offline
Personaly i'd do the 360 stroker, that's my plans for my 68 Dart. You have a trans for a smallblock how about that BB? I've seen SB stroker kit's as low as $1100 for a 500hp max kit. Also exta weight is extra weight if you go BB regardless of handling. My Dart has a 318 in it with 10:1 comp,750 Holley, Weiand intake, 2.02 360 J heads, .528 solid cam, msd ign, 4200 stall in 727 w/reverse manual VB, 3:91 SG. She rev's to 6800 and moves the Dart right along nicely, the 408 should be a blast.
Re: A body: BB v SB [Re: Donny] #762277
08/01/10 01:52 AM
08/01/10 01:52 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
With a responce like this then, why are you 2nd. guessing yourself, he was just giving you some input on what you were asking
Re: A body: BB v SB [Re: Donny] #762278
08/01/10 04:51 AM
08/01/10 04:51 AM
MNobody Offline
MNobody  Offline
500hp from a 9:1 motor?
