Screw/bolt kit recommendations #761997
07/31/10 12:08 PM
07/31/10 12:08 PM
Chicagoland
cudastruction Offline OP
Chicagoland
I know there are a lot of vendors out there so I am looking for some recommendations for a screw/bolt kit for a 71 cuda. I am looking for original looking parts and as large a kit as possible (the more the better).
I will be buying an interior and exterior kit.
Al
Re: Screw/bolt kit recommendations [Re: cudastruction] #761998
07/31/10 12:46 PM
07/31/10 12:46 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
http://amkproducts.com/default.htm
You may want to check them out.
Jules
Re: Screw/bolt kit recommendations [Re: JulesdaWiperman] #761999
07/31/10 01:18 PM
07/31/10 01:18 PM
SE Pa.
LimeliteAero Offline
SE Pa.
Are the AMK kits correct hardware or just a kit that was put together to fill the need?
Re: Screw/bolt kit recommendations [Re: LimeliteAero] #762000
08/01/10 08:51 AM
08/01/10 08:51 AM
super gas
super gas
I am sorry I do not know.
That is why I said to check them out.
A phone call may help.
Jules
Re: Screw/bolt kit recommendations [Re: cudastruction] #762001
08/01/10 09:09 AM
08/01/10 09:09 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Avoid anything from Penstar. Incorrect parts and horrible to deal with.
Common sense is a flower that does not grow in everybody's garden
Re: Screw/bolt kit recommendations [Re: cudastruction] #762002
08/01/10 11:12 AM
08/01/10 11:12 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'm a dealer for AMK. As are a few others including R/T Specialties, E-Body Ed.
I will say there is no such thing as a 'complete' correct screw bolt kit avail today. Every bolt or fastener just isn't avail at this time. Although AMK gets the clostest to OE as anything avail today. But I believe you'll need fasteners from several different sources to get them all.
IMO the first contact should be to Tom Race at R/T Specialties. He is a dealer for numerous fastener suppliers (far beyond myself) and will be the best to get the closest to complete coverage.
Re: Screw/bolt kit recommendations [Re: gtx6970] #762003
08/01/10 11:15 AM
08/01/10 11:15 AM
SE Pa.
SE Pa.
Thanks Bill
Great advice.......
Re: Screw/bolt kit recommendations [Re: gtx6970] #762004
08/01/10 08:52 PM
08/01/10 08:52 PM
Chicagoland
Chicagoland
Thanks for the info.
Al
Re: Screw/bolt kit recommendations [Re: Ron_M] #762005
08/02/10 12:39 AM
08/02/10 12:39 AM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
