new car HP rating?
#761637
07/30/10 06:49 PM
07/30/10 06:49 PM
Posts: 3,075 Eastern Ohio
mopowergtx
Eastern Ohio
How do they rate the new Dodges horsepower wise? Is the numbers they are throwing out there flywheel or rearwheel horsepower? Like for examples my 2004 Dodge Ram 5.7 is rated at 345HP. Where is that 345HP number derived from? Back at the rear wheels through exhaust and running the belt for the alternator and water pump breathing through the stock air box? Or sitting on a run stand in the engineering dept. dyno room? Why I ask is I thought they went to rear wheel horsepower years ago but if thats so it sure doesnt add up on a ET calculator for my buddies 07 Ram 3/4 ton 4x4 from last nights trip to the dragstrip. He had a trap speed of 80 mph and we figure it to weigh 6500 with him in it. You enter 6500 lbs then 80 mph you get 260 rear wheel HP. You put that in the next line it spits out a 17.03 ET. His best run last night was 16.98 but he had several 17.04's and 17.1's. So dang that seems to really justify that calculators rationing. What do you guys think? ET calculator
Re: new car HP rating?
[Re: mopowergtx]
#761639
07/30/10 09:09 PM
07/30/10 09:09 PM
Posts: 709 California
BigDaddy440
California
Modern HP ratings are flywheel numbers, NOT rear wheel numbers. I believe I read just a few years ago manufactures were forced / agreed to assimilate on how they rate their vehicles' power, to obtain more accuracy across the board. Same with fuel mileage claims as well.
Rear Wheel numbers are a fairly new (last 10+ years or so) way to easily gauge how much power an engine is putting out after the drive train has absorbed its toll. Manual trans and lighter duty rear-ends will absorb less than a stingy auto trans with a converter. I'd assume a Dana 60 takes more “oomph” to turn than a 8.75 too. Also torque / stall converters multiply torque, so real wheel torque numbers will be inflated some with an auto trans.
There are three (maybe four) popular chassis dyno systems, with Dynojet being the most popular (industry standard). The numbers can be listed corrected and non-corrected. Non-corrected (SAE) numbers are what the car actually put out that day. Corrected numbers take into consideration other factors such as weather and issue performance number based on a correction factor, so that someone in Death Valley California in July can compare their numbers with someone is Denver Colorado in January.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: mopowergtx]
#761641
07/31/10 03:28 AM
07/31/10 03:28 AM
BigDaddy440
California
Its hard to say, but I'd assume 30-40 years ago HP ratings might have been less accurate than more modern rating systems. If your engine was putting out 140 flywheel HP you could expect to see 115 at the rear wheels. With your modifications and possibly a little more factory HP than advertised, your estimated 130 rwhp might be right on. If you indeed have 130 rwhp, you most likely have about 160 flywheel HP. Drive Safely
[Re: BigDaddy440]
#761642
07/31/10 04:19 AM
07/31/10 04:19 AM
DaytonaTurbo
Manitoba, Canada
The auto manufacturers have NEVER rated their vehicles or motors at power at the wheels or transmission. It has ALWAYS been power at the flywheel. The difference being 1971 and earlier was SAE Gross power. SAE Gross = no belt driven accessories, no air cleaner, dyno headers/exhaust system. 1972+ was SAE Net which had the engine running water pump, alternator, air cleaner and stock type exhaust system. This standard was brough into effect to more accurately reflect real-world performance. A few years ago they came up with a voluntary SAE Certified, which the dyno test is basically the same as a SAE Net test, but done at an independant 3rd party dyno/dyno operator so the test conditions can't be manipulated by the manufacturer.
[Re: DaytonaTurbo]
#761643
07/31/10 10:48 AM
07/31/10 10:48 AM
mopowergtx
Eastern Ohio
Ah. I see. So my minor modifications have improved upon the stock HP rating it would seem enough to make a difference where you could tell. Seat of the pants said it did a little bit. I didnt get a baseline last year when it was 100% stock. I wanted to do that this year before I installed the 2.94 8 1/4", stock 340 cam, and a factory cast iron manifold with stock '75 Thermoquad.
[Re: 5spdcuda]
#761645
07/31/10 12:45 PM
07/31/10 12:45 PM
DaytonaTurbo
Manitoba, Canada
Vehicle weight and trap speed tells more about actual power output than dyno #'s that vary according to individual dynos and their operators.
Yup, that would be why I've often heard dynojet brand dynos referred to as ego-jet!
[Re: DaytonaTurbo]
#761646
07/31/10 02:12 PM
07/31/10 02:12 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
The new 5.0 Mustang makes it's rated 412 hp at the wheels...
A new iron curtain drawn across the 49th parallel
[Re: BigDaddy440]
#761650
07/31/10 06:10 PM
07/31/10 06:10 PM
DaytonaTurbo
Manitoba, Canada
While there are differences between dyno outputs, baseline dyno pulls of production cars have shown a strong level of consistency between like cars on the same types of dyno systems across the country.
Which is why they brought in the voluntary SAE Certified rating system, so a manufacturer could say this is how much HP our car produces, compared to other manufacturers cars tested with the same 3rd party rating system. Probably the closest to a level playing field we will get for dynos. But in the end I agree with what's been said, it's the track times I care about.
[Re: 67autocross]
#761652
07/31/10 06:36 PM
07/31/10 06:36 PM
Posts: 459 pana illinois
bigblock4x4
pana illinois
The 5.0's are posting 12:30's at 110 mph with nothing more then slicks and must be at least 3800lbs, how much horse power is that at the flywheel?
doesn't really matter too much it's a ford.
