Re: That was fun....T&T night with the stick
[Re: StripeHOG]
#761313
07/30/10 09:29 AM
07/30/10 09:29 AM
Posts: 528 Oak Grove, MN
lowflyingdart
Oak Grove, MN
Congrats on a fun and sucessful testing session. I'm jelous, it'll be next season before I get to test my stick car.
"I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
[Re: LAR_414]
#761315
07/30/10 05:10 PM
07/30/10 05:10 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
The only thing I can think of is the mass of the engine/trans times the acceleration. (or might think inertia)
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: LAR_414]
#761316
07/30/10 06:39 PM
07/30/10 06:39 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Slap a limiter on it and forget about it Man I wish mine was done What clutch setup are you running....I'm going through a learning curve.... Rickster
[Re: LAR_414]
#761317
07/30/10 08:44 PM
07/30/10 08:44 PM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
One thing that I do have to fix is the fact that my engine/trans seems to be moving Backwards....toward the rear of the car. It's been a problem lately, and I even repositioned my mounts (solid) forward about 3/8" a month ago. Well, last night the engine is back again, and the distrib is hitting the firewall and my Z bar is no longer positioned correctly.
Looked at my K member and the Solid mount is kinda twisted and has bent the attaching area of the K member.
What gives? Obviously I need to rebrace some stuff here.
But WHY would the engine WANT to move backwards? What force is in place that would cause this?
My pedal pressure is super light, so it's not from the clutch!
It's probably from when it stood up in the air, it slid backwards
Them sticks sure are fun ain't they?
[Re: rickstershemi]
#761318
07/30/10 09:04 PM
07/30/10 09:04 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Rickster
, If you think it pulls the wheels now, what it off a limiter .
[Re: joedust451]
#761320
07/30/10 11:12 PM
07/30/10 11:12 PM
rickstershemi
Rickster
I thinks we are talking about two different things here....by limiter I mean to limit engine movement
Rickster
[Re: LAR_414]
#761322
07/30/10 11:37 PM
07/30/10 11:37 PM
rickstershemi
I'm running a McLeod RST Twin Disc clutch. Simply a fantastic street strip clutch. It's perfect for what I do.
I'll definitely be designing a limiter for the engine movement, that's for sure. Just not sure why it did it. It leaves hard, but I wouldn't think hard enough to slide backwards....but maybe?
Yeah, I was very surprised to hear it moved with the solid mounts, thats a little confusing...
First outing at the track in my sons truck (mild 360) the dizzy slammed the firewall (rubber mounts) and broke the rotor....epoxied it back together and it's still running...
I'm looking at going with the same setup on the clutch
Rickster
Re: 383man
[Re: LAR_414]
#761325
07/31/10 12:16 PM
07/31/10 12:16 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Hey Larry - good job slammin through the gears. Thats old school drag racing right there!
2 kids and a dog
383man
[Re: LAR_414]
#761327
07/31/10 01:12 PM
07/31/10 01:12 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I was the only stick car in the "slick" lanes. There were a bunch in the street tire lanes,...typical mustangs and camaros (late models). Really bad shifting going on over there!...not that I'm some expert.'
One cool car was a F.A.S.T. style 60's firebird on Polyglass tires. Low 12's with a stick. That was pretty impressive to watch.
Its funny to watch the stick cars at the track as I notice most of the stick drivers are not very good and when you see one really hitting the gears you can appreciate how good a driver they are. Ron
Re: 383man
[Re: 383man]
#761328
07/31/10 01:21 PM
07/31/10 01:21 PM
oldiron
New Hampshire, USA
I like seeing them try - many of the transmissions just don't shift under wot at higher rpms, but at least they're giving it their best shot
Re: 383man
[Re: LAR_414]
#761329
08/01/10 09:45 AM
08/01/10 09:45 AM
Posts: 1,832 Fort Morgan
1OFNONE
Has been a member for quite a few years, so relax.
Fort Morgan
What track did you go to? Any pics or vids? Hands down, your Dart is my fav on the board and has been for years.
So the bartender says to the horse " Gee, Why the long face?"
Re: 383man
[Re: 1OFNONE]
#761330
08/01/10 10:38 AM
08/01/10 10:38 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Good job Larry, sounds like a good time!
Re: 383man
[Re: LAR_414]
#761333
08/01/10 11:08 AM
08/01/10 11:08 AM
rickstershemi
Thanks....I race it at Pittsburgh Raceway Park. They do a fantastic job keeping traction on T&T nights.
My dad took vid's, mostly to see what happens with the rear on launch. That has helped get the thing off the line. Slow motion replay is a big help.
I don't know how to get the things to post, but I'll have to work on it.
I saw one of your older threads on face plating and pro shifting and have to agree that for a street car that doesn't need to be shifted at 7-8000 rpm it really wouldn't be cost effective....I'm actually staying with a narrower tire on purpose to hopefully limit breakage
Sure would be awesome to see a couple of your video's
Rickster
[Re: LAR_414]
#761334
08/01/10 05:56 PM
08/01/10 05:56 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
I had the same problem when I went to a stick. Even tho the 60ft. was the same the "hit" is more violent. What was OK with auto,nolonger worked. Run a pair of struts from the bell to the K-member,or back to the trans/frame crossmember
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
