Re: 383man
[Re: LAR_414]
#761329
08/01/10 09:45 AM
08/01/10 09:45 AM
Posts: 1,832 Fort Morgan
1OFNONE
Has been a member for quite a few years, so relax.
Fort Morgan
What track did you go to? Any pics or vids? Hands down, your Dart is my fav on the board and has been for years.
So the bartender says to the horse " Gee, Why the long face?"
Re: 383man
[Re: 1OFNONE]
#761330
08/01/10 10:38 AM
08/01/10 10:38 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Good job Larry, sounds like a good time!
Re: 383man
[Re: LAR_414]
#761333
08/01/10 11:08 AM
08/01/10 11:08 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Thanks....I race it at Pittsburgh Raceway Park. They do a fantastic job keeping traction on T&T nights.
My dad took vid's, mostly to see what happens with the rear on launch. That has helped get the thing off the line. Slow motion replay is a big help.
I don't know how to get the things to post, but I'll have to work on it.
I saw one of your older threads on face plating and pro shifting and have to agree that for a street car that doesn't need to be shifted at 7-8000 rpm it really wouldn't be cost effective....I'm actually staying with a narrower tire on purpose to hopefully limit breakage
Sure would be awesome to see a couple of your video's
Rickster
Re: That was fun....T&T night with the stick
[Re: LAR_414]
#761334
08/01/10 05:56 PM
08/01/10 05:56 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
One thing that I do have to fix is the fact that my engine/trans seems to be moving Backwards....toward the rear of the car. It's been a problem lately, and I even repositioned my mounts (solid) forward about 3/8" a month ago. Well, last night the engine is back again, and the distrib is hitting the firewall and my Z bar is no longer positioned correctly.
Looked at my K member and the Solid mount is kinda twisted and has bent the attaching area of the K member.
What gives? Obviously I need to rebrace some stuff here.
But WHY would the engine WANT to move backwards? What force is in place that would cause this?
My pedal pressure is super light, so it's not from the clutch!
I had the same problem when I went to a stick. Even tho the 60ft. was the same the "hit" is more violent. What was OK with auto,nolonger worked. Run a pair of struts from the bell to the K-member,or back to the trans/frame crossmember
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
