Re: Modern wiper motor interchangability?
[Re: stumpy]
#761091
07/29/10 10:19 PM
07/29/10 10:19 PM
Posts: 838 OH-IO
moparman383
OH-IO
Maybe it isn't worth all the cobbling necessary.
True. I was wondering if it would be a direct swap or take some work. Just kinda curious and figured this crowd would know.
[Re: moparman383]
#761095
07/30/10 03:58 AM
07/30/10 03:58 AM
Posts: 357 Lake Elmo, MN
Evil Monkey
Lake Elmo, MN
I would think that finding a modern wiper motor that would fit the firewall hole, connect to the wiper linkage, sweep the wipers correctly across the windshield, and park correctly, would be a longshot at best. I've never looked into it, so maybe there is something out there that would work without too much cutting and cobbling, but unless someone else has done it and knows what will work, it could be a long, long search trying to find one that works.
I'm sure it could be done, but I would think it would take lots of cutting, cobbling, some redesigning, and a whole lot of swear words to make a modern motor work, and it really wouldn't be worth the effort.
1974 'Cuda 360/TKO
1990 Ram Van
1998 Neon
[Re: moparman383]
#761097
07/30/10 07:41 AM
07/30/10 07:41 AM
Posts: 2,984 Montreal,Quebec,Canada
JulesdaWiperman
super gas
super gas
Ok, this is kind of a weird question I know, but I hate the old wiper motors, and was wondering if anyone knew an alternative (hint hint, a cheap one) that I could use on my 71 Challenger. I don't care about originality, I just want something I can go grab off the shelf at my local auto parts dealer that will work better than original. I realize I will have to have a switch that allows for enough speed settings.
This may be just a pipe dream, but I wanted to see what kind of feedback I got.
Thanks.
Brad
What is it exactly that you hate about them ?
Jules
[Re: moparman383]
#761099
07/30/10 08:34 PM
07/30/10 08:34 PM
Posts: 10,234 Someplace you aren't
SomeCarGuy
I thought the 2 speed motors were only about 50 bucks from the chain stores. Cardone brand maybe??? You may be wanting 3 speed so
I want my fair share
[Re: SomeCarGuy]
#761100
07/30/10 10:05 PM
07/30/10 10:05 PM
Posts: 650 Kansas
racincuda
Kansas
I would like the intermintent settings that you get with newer cars & trucks but hav no idea how to make that work with these old two & 3 speed motors. Im not electricaly creative
[Re: ConcoursCreation]
#761102
08/04/10 09:41 PM
08/04/10 09:41 PM
Posts: 2,190 SW MO
closer9
SW MO
There is a direct bolt on that will fit the hole in your firewall. I have also always toyed with the idea. Just find a: 1976-1989 Plymouth Volare, Dodge Aspen, Chrysler LeBaron, Dodge Diplomat, Plymouth Gran Fury, Town & Country, New Yorker, or Fifth Avenue. Some of them came with intermittent wiper systems. They look like the early 2 speed motors but have 1 extra terminals on the motor where the harness plugs into it. Of course you will need the switch, delay control box/harness and I would say the connector that goes on the back of the wiper switch itself. With that said....I think the only "bolt In" part is going to be the wiper motor. Link connecting your 2 wiper arm pivots should be fine but the one going to the drivers side pivot from the wiper will almost for sure have to be modified. As for a wiper motor crank.....this is why I think the link connecting to it will have to be modified but maybe not....they came with the plastic press in bushings. I'm almost sure that there is a bronze bushing style crank that will work but never have gotten around to trying all the different ones I have. I will try and dig some pics up. Hope this helps Jerry
Interesting. I will have to play around with this. I will be parting out a 5th Ave, and had wondered about the wiper motor/switch.
Daily: '19 Frontier 4WD Belle: '67 Belvedere Convertible, 318/727 in Go ManGo! Other: '64 C10, 283/3 on the tree
[Re: closer9]
#761104
08/05/10 08:57 AM
08/05/10 08:57 AM
Posts: 32 Gods Country
ConcoursCreation
Gods Country
There are are non intermittent motors on those models also......it was an option.
