Trans coolers
#760875
07/29/10 04:52 PM
07/29/10 04:52 PM
Posts: 425 Eastern Ontario
shaker340
Eastern Ontario
Is it a good idea to bypass the radiator trans cooler to an after market trans cooler? or should the rad cooler be used as well?
The application is a 2003 Neon, where I have read that the rad trans coolers have leaked.
Thanks, Mike
2008 Challenger SRT8 1940 Chrysler Royal coupe
Re: Trans coolers
[Re: TheHemi]
#760878
07/29/10 05:32 PM
07/29/10 05:32 PM
shaker340
Eastern Ontario
Yes its a stock daily driver. I have heard that its becoming common for the rad trans cooler to leak antifreeze into the trans. So I thought maybe bypassing the rad alltogether would prevent the chance.
Mike
Re: Trans coolers
[Re: dOoC]
#760880
07/29/10 06:03 PM
07/29/10 06:03 PM
DaytonaTurbo
Manitoba, Canada
Save your money....uNless it IS actually leaking. And THEN replace it with a stock OEM type.
Probably cheaper and easier to replace with another stock rad than to buy an install an external trans cooler.
Re: Trans coolers
[Re: mopars4ever]
#760883
07/30/10 07:31 AM
07/30/10 07:31 AM
shaker340
Eastern Ontario
The above post is why I am thinking of adding a trans cooler and by passing the rad cooler. I do agree that this is not common, but does happen and so preventative measure could save the trans down the road.
I guess the question is can the aftermarket cooler work on its own in all situations? I have a 4" x 11" x 3/4" trans cooler, it should be big enough for a neon?
Re: Trans coolers
[Re: dOoC]
#760885
07/30/10 01:35 PM
07/30/10 01:35 PM
shaker340
Eastern Ontario
Doc, good point on the sensors. There is no leakage on this neon. I do have a question; this neon was given to me for FREE. when I picked it up, the car would not move in any gear. The owner of it was told it was the pump, so he didn't want to fix it.
I winched it on my trailer and took it home where it sat for 6 months until last week. I pulled it in the shop and pulled one of the lines to the rad cooler to see if there was any fluid being pumped. And there was, so I put that oil back in it and checked the level, it was low about a quart, so I topped it off. And then drove the car oput of the shop....all the gears work fine...???? I have tested this car for about 20 miles and it shifts perfectly. Your thoughts???
I just finished an trans oil and filter change. There was sludge and metal shavings on the magnet.
