Bench testing Voltage Limiter? #760845
07/29/10 04:21 PM
07/29/10 04:21 PM
Flint, MI
Gusteve Offline OP
I Love the Unicorn Song!!
Gusteve  Offline OP
Flint, MI
OK - I'm a little less ranty about this subject today than I was last night.
How do I bench test a voltage limiter? Seems like I'd:
Connect 12v+ to the 12v prong.
Connect a ground to the ground prong.
Connect my voltmeter to the 5V prong and also to the ground prong, and watch for 5V.
Do I need that little condensor thing connected? (And what's that for anyway? To stabilize the 5V pulse?)
FWIW - this is a new solid state limiter from redlinegauges. I just want to confirm it's good before I move on to the next step.
Re: Bench testing Voltage Limiter? [Re: Gusteve] #760846
07/29/10 06:54 PM
07/29/10 06:54 PM
Flint, MI
Gusteve Offline OP
Gusteve  Offline OP
Flint, MI
I just spent some time searching, and I still don't see posts that talk about how to test one of these. Would my above posted process work?
Also - it appears that I don't need the capacitor thing at all, from what I recently read. Is that right?
Thanks in advance.
(How did people work on old cars before the internet?)
Re: Bench testing Voltage Limiter? [Re: Gusteve] #760847
07/29/10 08:24 PM
07/29/10 08:24 PM
Houston, TX
Crunchy_Frog Offline
Houston, TX
I wouldn't test it without a load. I would try a 500 ohm 1/8 watt. But that's me.
Re: Bench testing Voltage Limiter? [Re: Crunchy_Frog] #760848
07/29/10 08:37 PM
07/29/10 08:37 PM
Flint, MI
Gusteve Offline OP
Gusteve  Offline OP
Flint, MI
Hmmm....wouldn't the voltmeter between the 5V prong and ground provide the load? I'm a geek but some of this basic electrical stuff sometimes is a mystery to me.
Re: Bench testing Voltage Limiter? [Re: Gusteve] #760849
07/29/10 08:53 PM
07/29/10 08:53 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Yes the meter is enough load.
Re: Bench testing Voltage Limiter? [Re: Gusteve] #760850
07/29/10 09:28 PM
07/29/10 09:28 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The purpose of the condenser was to mute the pops from the voltage limiter when its internal contacts would make/break.. This could be audible in the front radio speaker. But if you are using a solid-state limited it is not needed..
Just my $0.00...
Re: Bench testing Voltage Limiter? [Re: stumpy] #760851
07/30/10 08:59 AM
07/30/10 08:59 AM
Houston, TX
Houston, TX
The meter will be a 10 megaohm load. I=E/R... That would be .5 microamps. Meters are not intended to be a load. Although, it probably wouldn't harm it. Some people will say it's fine. I'm not other people, and I would use a load. Ultimately, the choice is yours.
Re: Bench testing Voltage Limiter? [Re: Crunchy_Frog] #760852
07/30/10 09:16 AM
07/30/10 09:16 AM
Flint, MI
Gusteve Offline OP
Gusteve  Offline OP
Flint, MI
How about if I just used a 12V lightbulb from the cluster? Or would that throw off my meter readings?
And by they way, thanks for bringing this up. Whether the meter is enough of a load or not is one thing, but if you hadn't mentioned this I probably would have applied the 12V first, and then proceeded to touch the meter to the 5V prong, so there would have been a period of time where there was no load at all.
Re: Bench testing Voltage Limiter? [Re: Gusteve] #760853
07/30/10 09:57 AM
07/30/10 09:57 AM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
Meter by itself will work fine; I've tested a couple this way. Keep in mind that on the original units you won't see 5Vdc on the output. You'll see your meter go to 12Vdc (or whatever the input voltage is) and stay there until the internal coil heats up. After a a minute or so, the meter will start showing the output switching on and off to provide an approximate average of 5V. You can add the capacitor and see that it will slow down the movement of the needle on your meter (if the cap is working correctly) as the regulator switches on and off.
