XE274 cam 340. Do I need to machine the heads? #76069
06/19/08 06:02 PM
06/19/08 06:02 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
I have a 340,rebuilt to 71 specs. Looking to upgrade to an XE274 cam kit. The website says the heads will need machining to make it work. I called Comp and I could not get a straight answer out of the guy on if i really needed to do this. Once and for all, what will it take to make this cam work in my motor?
Re: XE274 cam 340. Do I need to machine the heads? [Re: OA5599] #76070
06/19/08 06:12 PM
06/19/08 06:12 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
The recommended springs for the cam are double springs which will require machining to make them fit.
Re: XE274 cam 340. Do I need to machine the heads? [Re: AdamR] #76071
06/19/08 07:05 PM
06/19/08 07:05 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Thanks for the input. How much $$$ on average would that machine work run me?
Re: XE274 cam 340. Do I need to machine the heads? [Re: AdamR] #76072
06/19/08 07:31 PM
06/19/08 07:31 PM
recomended yes.. but i'm sure theres a single spring that will do the job.
Re: XE274 cam 340. Do I need to machine the heads? #76073
06/19/08 07:37 PM
06/19/08 07:37 PM
CA
David Lee Offline
David Lee  Offline
CA
I agree, thats not that big of cam, let me check what springs I run on my stocker and get back to you
Re: XE274 cam 340. Do I need to machine the heads? [Re: David Lee] #76074
06/19/08 07:47 PM
06/19/08 07:47 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Thanks. I'm all about preventative maintenance, but if I don't actually need the double springs that require machining, then that would save time and $$$.
Re: XE274 cam 340. Do I need to machine the heads? [Re: David Lee] #76075
06/19/08 07:55 PM
06/19/08 07:55 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
It may not be big but its got fast ramps. Dont try and out think the engineers who designed it. If you dont use there recommended parts dont expect help when you have a problem.
Re: XE274 cam 340. Do I need to machine the heads? [Re: AdamR] #76076
06/19/08 07:57 PM
06/19/08 07:57 PM
what problems exactly? + FYI.. engineers arn't always the brightest pee in the POD.
Re: XE274 cam 340. Do I need to machine the heads? #76077
06/19/08 11:43 PM
06/19/08 11:43 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
IMO, depends on how hard you plan on turning it.
If you don't plan on anything over 5500, then a stout single spring will work.
Running it to the max RPM, put the double 995 spring on it. I just ran into this very decision. I have 3 choices, 484, XE274, XE275HL. The first two you could get away with a stout single and run it easy. Plan on turning it 6K+, a single may control it, but why chance it. Brian at IMM and I had a pretty lengthy talk about this. He had nothing to gain from going either way and strongly suggested the double spring set up.
Machine the heads, drop on a locator and you have one less potential issue to worry about.
Do it once, do it right!
I'd guess about $100 for cutting the guide/spring seats and locators.
Re: XE274 cam 340. Do I need to machine the heads? [Re: RobX4406] #76078
06/20/08 09:37 AM
06/20/08 09:37 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
My 340 has an XE274.
$120 at my machine shop a couple years ago. Worth it for peace of mind, plus I regularly turn it to 6,200 rpm at the track, when it stops pulling. If I had to baby it because of the springs that would take a lot of fun out of it, lol. My opinion, I would do it and not worry about it anymore.
Re: XE274 cam 340. Do I need to machine the heads? [Re: dustergirl340] #76079
06/20/08 09:40 AM
06/20/08 09:40 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
My 340 has a XE274.
I thought the 274 xe was good to rev up to 5800. You sure your still making power at 6200?
Re: XE274 cam 340. Do I need to machine the heads? [Re: Mopar-Al] #76080
06/20/08 09:44 AM
06/20/08 09:44 AM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
I get my best ET and MPH at 6,200. I've tried every shift point starting at 5,300 and worked my way up. I've made several hundred passes so I know the engine and the car very well.
Re: XE274 cam 340. Do I need to machine the heads? [Re: Mopar-Al] #76081
06/20/08 09:59 AM
06/20/08 09:59 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Thats a general guideline. Every combo will be different.
Re: XE274 cam 340. Do I need to machine the heads? #76082
06/20/08 10:37 AM
06/20/08 10:37 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
you said that right,
Re: XE274 cam 340. Do I need to machine the heads? [Re: Dakota_Don] #76083
06/20/08 12:35 PM
06/20/08 12:35 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Comp likes lots of pressure on thier lobes. It's for a reason, and ropm is only part of it. The XE268 is fine with singles. Anything larger should have double springs. Saying "I did it and it worked" is as good as claiming the engineers are clueless. Why put in a cam you can't make use of because the springs and rpoer setup are too much $$? Cutting the guide tops and spring seats as part of a valve job is usually a metter of $100-150. If they have to pull them apart, do it, wash it, and replace the seals, and assemble, it will be more. And, expect to get the retainers and locks to match teh spring. Again, there's one right way, and million other ways that might work.
Re: XE274 cam 340. Do I need to machine the heads? [Re: moper] #76084
06/20/08 04:13 PM
06/20/08 04:13 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
This peaks my curiosity. I'm running the 274 in my 360 with single springs. I've got Eddie heads and the springs that came with them were rated just over .500" of lift (bought them assembled), so I didn't give it anymore thought. Am I asking for trouble??
Re: XE274 cam 340. Do I need to machine the heads? [Re: OA5599] #76085
06/20/08 05:52 PM
06/20/08 05:52 PM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
see ya added a jeep to your collection, how ya like it?
Re: XE274 cam 340. Do I need to machine the heads? [Re: OA5599] #76086
06/20/08 05:56 PM
06/20/08 05:56 PM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
buy the way, yes on the springs and head work, or go EDDY.
