70 charger voltage limiter testing #760803
07/29/10 02:30 PM
07/29/10 02:30 PM
louisiana
mopar70charger Offline OP
louisiana
is there a way to test voltage limiter for the gauges and if so how would u do it..and whats its purpose..thanks
Re: 70 charger voltage limiter testing [Re: mopar70charger] #760804
07/29/10 02:42 PM
07/29/10 02:42 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Your talking the one for the gauges? if you have ever noticed all your gauges spike for a second ditch it and get a solid state. Maybe someone else can help???
Re: 70 charger voltage limiter testing [Re: ademon] #760805
07/29/10 03:50 PM
07/29/10 03:50 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
It's purpose is to drop 12v to 5v so you don't smoke the gauges. It supplies the reduced voltage to the windings in the gauges that become magnetized and make the needle move. The windings are too light to carry 12v. The grounded sending units create differing resistence to the gauges controling the ammount of magnetic force that moves the needles. If you look at the terminal side you will see Ign which is 12v in, a ground to the case and a third terminal which is output. If you apply 12v to the Ing and ground the case you should get a pulsing power out on the third terminal which will average to 5v. It works somewhat like a turn signal flasher.
Re: 70 charger voltage limiter testing [Re: stumpy] #760806
07/29/10 04:37 PM
07/29/10 04:37 PM
louisiana
louisiana
thanks, i will try that..i really need an expert on wiring this all up here on the car..
Re: 70 charger voltage limiter testing [Re: mopar70charger] #760807
07/29/10 04:41 PM
07/29/10 04:41 PM
louisiana
louisiana
so i understand this a little clearer, are you sayin this is for all the gauges or just the fuel gauge
Re: 70 charger voltage limiter testing [Re: mopar70charger] #760808
07/29/10 04:43 PM
07/29/10 04:43 PM
Grand Prairie,Texas
Grand Prairie,Texas
Gas, oil and temp.
Re: 70 charger voltage limiter testing [Re: stumpy] #760809
07/29/10 04:52 PM
07/29/10 04:52 PM
Flint, MI
Gusteve Offline
I Love the Unicorn Song!!
Gusteve  Offline
Flint, MI
I can't believe I just posted nearly the exact same question....must be a popular problem today.
