early 360 block thickness (sonic test)
#760643
07/29/10 08:39 AM
07/29/10 08:39 AM
Posts: 162 monticello,ms
andy3965
monticello,ms
i dropped my '73 standard bore 360 block off at the machine shop tuesday and the machinest stuck his sonic tester in a couple of the cylinders for a quick look and said "wow you got a good thick block".I asked what the numbers were and he said ".276 thrust .240 non-trust". if these numbers hold true for all the cylinders can it go to a 4.1" bore? i've heard that the early 360 blocks were built on the 340 tooling and could go the same bore as .60 over 340 (4.1"). i don't know how to do the math to find out max bore size. i'm just gonna go .30 over now but would be nice to know that it had 2 more rebuilds left in it. thanks, Andy
MOPAR BORN,MOPAR BRED,AND WHEN I DIE I'LL BE MOPAR DEAD!!!
Re: early 360 block thickness (sonic test)
[Re: andy3965]
#760644
07/29/10 08:49 AM
07/29/10 08:49 AM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Why waste your block for a few cubes? You are not going to gain a whole bunch just from a max over bore.
But to answer your question, If they are all that thick, then I guess ya could. But remember that limits the block, and if something happends you might have to start over.
![](/ubbthreads/images/graemlins/Twocents.gif)
Kasey
[Re: emarine01]
#760646
07/29/10 04:54 PM
07/29/10 04:54 PM
andy3965
monticello,ms
as stated in the original post i am only going .30 over. just wanted to know if i would be able to get two more rebuilds out of it. 4.06 & 4.10? or possibably 4.08?
[Re: andy3965]
#760648
07/29/10 06:59 PM
07/29/10 06:59 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
After three .030 rebuilds, which unless someone REALLY screws up, should never happen, you'd be at .231 thrust and .195 non thrust, which is very good. The problem as mentioned is, make sure ALL bores are sonic checked. You often get to the last cylinder and find its something stupid like .070 between cylinders.Check them all, if it maintains that kind of number, you have an exceptional block.
RIP Monte Smith
[Re: ccarson]
#760650
07/29/10 08:35 PM
07/29/10 08:35 PM
andy3965
monticello,ms
thanks for the info guys, i was just thinking about rebuilds using off the shelf sizes.this 408 i'm building is going in my '75 shortbox d100. i have a set of w2 econos with light port job(don't have flow numbers, they at the machine shop now getting flowed) and i bought a custon bullet solid lift cam from ryanj. gonna use a victor intake, flat top pistons,gonna stay in the 10.5 range on compression.ryan said my combo will be about 550-570hp and around 530 tq. should be a nice motor for my truck.going to be a street truck with the ocassional run down the strip
[Re: andy3965]
#760653
07/30/10 12:55 AM
07/30/10 12:55 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
that block is thick compared to mine, your fine with what you want to do, my block was in the 200's some spots lower, good perhaps, not, but its still together,
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
