A-Body Disc Brake Kits...
#76042
06/19/08 05:29 PM
06/19/08 05:29 PM
I'm having a hard time looking for a disc brake kit for a '70 Dart with 9" drums and a 14" wheel diameter. Does anyone know of anywhere that carries disc brake kits for this application? Any help is much appreciated!!!
Re: A-Body Disc Brake Kits...
#76044
06/19/08 05:41 PM
06/19/08 05:41 PM
Posts: 833 Marietta, GA
Joatha
Marietta, GA
I believe that Scarebird had a conversion kit for the 9 inch drums to mount disk brakes on them. But, I don't know if they are making them still.
As mentioned above, the better bet is to convert it to the 73-76 disk set up. The 9 inch set up really isn't very heavy duty at all. The only caveat is that you'll also have to convert from the small bolt battern wheels to large bolt pattern wheels.
1966 Barracuda
1968 Barracuda convertible
1930 Ford Model A (soon to be hemi equipped)
2006 Dodge 3500 4X4 CTD Quad Cab
[Re: Joatha]
#76045
06/19/08 06:05 PM
06/19/08 06:05 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
And there's the rub. I have everything I need to do the fronts, but I've been searching for an 8.25" rear end for months with no success.
[Re: RokketRide]
#76047
06/19/08 07:45 PM
06/19/08 07:45 PM
Posts: 1,414 Stow ,Ohio
demon440
Stow ,Ohio
Wilwood has a disc brake conversion for the 9" drums. I bought this for my Demon, never used it, now don't need it. It has the big bolt pattern though. Will sell cheap.
[Re: demon440]
#76050
06/19/08 09:45 PM
06/19/08 09:45 PM
whats cheap???
