A-Body Disc Brake Kits... #76042
06/19/08 05:29 PM
06/19/08 05:29 PM
Anonymous OP
Anonymous OP
I'm having a hard time looking for a disc brake kit for a '70 Dart with 9" drums and a 14" wheel diameter. Does anyone know of anywhere that carries disc brake kits for this application? Any help is much appreciated!!!
Re: A-Body Disc Brake Kits... #76043
06/19/08 05:33 PM
06/19/08 05:33 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The first issue is the weak spindles on the 9" drum cars. Those need to be ditched no matter what. I'd look around for a set of 73-76 discs and use them.
Re: A-Body Disc Brake Kits... #76044
06/19/08 05:41 PM
06/19/08 05:41 PM
Marietta, GA
Joatha Offline
Joatha  Offline
Marietta, GA
I believe that Scarebird had a conversion kit for the 9 inch drums to mount disk brakes on them. But, I don't know if they are making them still.
As mentioned above, the better bet is to convert it to the 73-76 disk set up. The 9 inch set up really isn't very heavy duty at all. The only caveat is that you'll also have to convert from the small bolt battern wheels to large bolt pattern wheels.
1966 Barracuda 1968 Barracuda convertible 1930 Ford Model A (soon to be hemi equipped) 2006 Dodge 3500 4X4 CTD Quad Cab
Re: A-Body Disc Brake Kits... [Re: Joatha] #76045
06/19/08 06:05 PM
06/19/08 06:05 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
And there's the rub. I have everything I need to do the fronts, but I've been searching for an 8.25" rear end for months with no success.
Re: A-Body Disc Brake Kits... [Re: Fab64] #76046
06/19/08 06:38 PM
06/19/08 06:38 PM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
You may not want to go this route but:
http://www.moserengineering.com/Pages/Shop-Services/shopservices.html
Re: A-Body Disc Brake Kits... [Re: RokketRide] #76047
06/19/08 07:45 PM
06/19/08 07:45 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Wilwood has a disc brake conversion for the 9" drums.
I bought this for my Demon, never used it, now don't
need it.
It has the big bolt pattern though.
Will sell cheap.
Re: A-Body Disc Brake Kits... [Re: Fab64] #76048
06/19/08 08:48 PM
06/19/08 08:48 PM
Marietta, GA
Joatha Offline
Joatha  Offline
Marietta, GA
Well, the other alternative is to see if you can find a Kelsey-Hayes setup from 67-72. Its not exactly easy to find, though.
Re: A-Body Disc Brake Kits... [Re: demon440] #76049
06/19/08 08:56 PM
06/19/08 08:56 PM
USA
V
VS29H0B Offline
VS29H0B  Offline
V
USA
need it.
Will sell cheap.
Is that a '73 - 76 K member with all the pieces?
PM me with the details.
Thanks.
Like the women I have dated --- Always looking for a better deal ....
Re: A-Body Disc Brake Kits... [Re: demon440] #76050
06/19/08 09:45 PM
06/19/08 09:45 PM
Anonymous OP
Anonymous OP
whats cheap???
Re: A-Body Disc Brake Kits... #76051
06/23/08 04:35 PM
06/23/08 04:35 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Here is the Wilwood set-up with the 9" drum
to disc conversion.
