help #7 header tube is glowing red ! #760417
07/28/10 08:45 PM
07/28/10 08:45 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
i put a new cam/lifters in last week and just now had some time to start the motor for the break in. And the number 7 header tube was glowing red. what would cause this? it didnt happen before.
i ran the motor for about 4 mins then turned it off. any ideas? timing?
Re: help #7 header tube is glowing red ! [Re: AK_JH27] #760418
07/28/10 08:50 PM
07/28/10 08:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Check the timing, you need to advance it on break in but they all should have been glowing. You need the timing to be all in at 2000, that 35 degrees, or unburnt fuel is going to be burning in the header tube .
Re: help #7 header tube is glowing red ! [Re: JohnRR] #760419
07/28/10 10:47 PM
07/28/10 10:47 PM
MNobody Offline
MNobody  Offline
Intake leak at #7 ?
Re: help #7 header tube is glowing red ! [Re: MNobody] #760420
07/28/10 11:51 PM
07/28/10 11:51 PM
Intake leak at #7 ?
that's what I was thinking esp if all the rest are OK and that one is bright red (a drastic difference)
Re: help #7 header tube is glowing red ! [Re: AK_JH27] #760421
07/29/10 06:57 AM
07/29/10 06:57 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
And doing cam break in you should take out the power valve and go up 8 jet sizes.
Re: help #7 header tube is glowing red ! [Re: Dodgem] #760422
07/29/10 12:14 PM
07/29/10 12:14 PM
Northeast
dodg66440 Offline
dodg66440  Offline
Northeast
Years ago when I first installed my 440 I had a similar problem. #6 header tube was glowing red during cam break in. I shut it down and started searching for a leak. What I found in my situation was the rear carb stud wasn't threaded far enough down to properly seat the carb allowing air between it and the manifold. A new stud cured the problem. Something to look at.
Re: help #7 header tube is glowing red ! [Re: dodg66440] #760423
07/29/10 01:24 PM
07/29/10 01:24 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
On a stock BB intake, the power brake booster is connected to the #7 cylinder runner. Could be a power brake booster leak.
Re: help #7 header tube is glowing red ! [Re: 6PakBee] #760424
07/30/10 09:39 PM
07/30/10 09:39 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
good point
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
