socket/wrench to bust the nut off the lower BJ
BFH/pickle fork/ball joint seperater tool
socket for pivot pin nut
pliers for the t-bar clip
socket to run the t-bar adjuster down off the t-bar
prybar/BFH/vise grip to grab t-bar to hammer it back..maybe..depends if its stuck or the t-bar clamp tool
nut to remove strut rod nut..I pull the strut with the LCA myself..but either end..diff size so bring both size
some thing to remove the pin in the end of the strut rod if its there
maybe a jack if its not up
small tools for shock and misc stuff...wheel bearing/calaper/brake pads/lug wrench
some one to help you carry tools/parts is allways nice
not to hard to do..just depends on the car and where its at and maybe the condition of stuff
good luck
