Help please... Indy 360-1 realted question... #760136
07/28/10 02:12 PM
07/28/10 02:12 PM
hawkesbury, ontario, canada
80volare416 Offline OP
Hi guys, I'm new here. i'm 28 years old and built a street motor. i'ts a 416 small block with indy 360-1... now here's my issue. Last year i was running this motor with cast X heads fully ported by a known mopar guy in montreal with a solid flat tappet cam. motor made 518hp 504 torque. ran a 7.01 on the 1/8th in a 3500# volare with suspension issues.. now.. went on the dynon last week .. after spending over 7000K ... with indy heads and now a roller cam setup... motor made 538 and 509 torque. any guys had a simillar experience ? if so I'd really like your input... thanks in advance.
steve
Re: Help please... Indy 360-1 realted question... [Re: 80volare416] #760137
07/28/10 08:19 PM
07/28/10 08:19 PM
Delray beach, Florida
P
Performance Only Offline
P
i suspect either something else is "off" about your combo or you have some tuning issues to sort out.
machine shop owner and engine builder
Re: Help please... Indy 360-1 realted question... [Re: Performance Only] #760138
07/28/10 09:21 PM
07/28/10 09:21 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
What size headers are you running? Is the compression the same between the motors?
Re: Help please... Indy 360-1 realted question... [Re: 80arrow] #760139
07/29/10 02:14 PM
07/29/10 02:14 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
I'm no expert, but from what I read here by the small block head gurus, the Indy heads are not great out of the box, they need porting before they reach their potential. The question is what was done to the Indy heads?
And as Dan suggested, there's a lot of importance to the whole combo, so you might want to give more specifics for the experts to chime in.
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: Help please... Indy 360-1 realted question... [Re: kick_the_reverb] #760140
07/29/10 04:33 PM
07/29/10 04:33 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Has the intake been modified any in the upper plenum area? I found that the carb mnt flange hangs out under the throttle blades on mine. Jim
Re: Help please... Indy 360-1 realted question... [Re: 80volare416] #760141
07/29/10 06:56 PM
07/29/10 06:56 PM
well.. the heads are ported... CNC ported and were finished off by hand by my motor guy.. we made 339 @ 700 lift. my cam is a roller 649/651 with 1.6 ratio rockers making it close to 700 lift. my intake was retouched especially around the base since the bolts from the accelerator pump were hitting the intake not letting the carb sit down properly. the hedders are 1.750" super comps. the compression is exactly the same. not much but close to 10.50.. and was done with 94 octane pump gas.
thanks for the input guys.
Re: Help please... Indy 360-1 realted question... [Re: 80volare416] #760142
08/10/10 03:11 PM
08/10/10 03:11 PM
hey guys... just wanted to give you an update... just got out of the dyno yesterday... now to clarify one thing. after measuring the chambers on the heads... indy advertises 63 cc's. well after my head guy measured them twice... we got 67.8 cc's. making my compression gor down in the 9's which is way too low with 245cc runners. well even though all that. we made 562hp and 519 lbs/tq with 89 octane ethanol which i think is still fair. So i now have another project for this winter... new pistons !... hoping to get closer to the 600 mark on pump gas...
Steve
