Who has the best #760068
07/28/10 11:50 AM
07/28/10 11:50 AM
ohio
mike67net Offline OP
mopar addict
mopar addict
ohio
....tubular adjustable upper control arms? My ball joint pushed up and out of my control arm...ooops. Must by all of the monster 3 inch wheel stands my car does
Thanks,
Mike
Re: Who has the best [Re: mike67net] #760069
07/28/10 11:54 AM
07/28/10 11:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks,
Mike
If you just want to fix it you can tack weld it with
5 or 6 good tacks
Re: Who has the best [Re: MR_P_BODY] #760070
07/28/10 12:02 PM
07/28/10 12:02 PM
ohio
mopar addict
mopar addict
ohio
Thanks,
Mike
5 or 6 good tacks
I was just thinking about that
Re: Who has the best [Re: mike67net] #760071
07/28/10 12:06 PM
07/28/10 12:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
5 or 6 good tacks
I dont know why it came out... there's no load up
there it just holds the wheel vertical
Re: Who has the best [Re: MR_P_BODY] #760072
07/28/10 12:13 PM
07/28/10 12:13 PM
5 or 6 good tacks
How about rust and corrosion if he is in a state that uses salt in the winter
Re: Who has the best [Re: Cab_Burge] #760073
07/28/10 12:28 PM
07/28/10 12:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I never had one rust out and I'm in the biggest salt
state there is... might have been under size some or
if it was a replacement someone could have stripped
it putting it in.... JMO
Re: Who has the best [Re: mike67net] #760074
07/28/10 12:30 PM
07/28/10 12:30 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Try Bill at RMS.He makes some great parts.I hear a member here Bondo Bob does also.Rocky
Chrysler Firepower
Re: Who has the best [Re: therocks] #760075
07/28/10 04:26 PM
07/28/10 04:26 PM
ohio
mopar addict
mopar addict
ohio
Thanks for the replies. This car has never seen salt even though I'm in Ohio. It looked like it had rocked around in there for a while and slightly egg shapped the whole. It may have been because I took out the upper snubbers trying to get more travel in the front end. It bangs around quite a bit being a stick-shift car (it does a little dinky wheelie then does it again when I hit second). I cut then snubbers in half and am going to re-install them.
Anyway, I stuck a $14.00 Autozone ball joint in there and tacked it in the best I could. Should hold me till this winter, I may look at Bondo Bob's upper and lower control arms and have the k-frame lightened.
Thanks again
Mike
Re: Who has the best [Re: mike67net] #760076
07/28/10 05:08 PM
07/28/10 05:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks again
Mike
Yeah I dont like to have steel hitting steel... I
would cut them down and put them back in
Re: Who has the best [Re: MR_P_BODY] #760077
07/28/10 09:49 PM
07/28/10 09:49 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Maybe in the past someone pressed the ball joint in, instead of threading it in. I know, that would have to be a good press!
I worked with a guy who has had a bunch of old mopars that argued with me about upper ball joints pressing in. I had to show him a ball joint socket and he finally looked it up in a manual. A little late after he pressed them in for many years.
Re: Who has the best [Re: Bigbeep] #760078
02/07/12 03:36 PM
02/07/12 03:36 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I have seen them get overtightened and stripped out.
67' charger 499 RB 10.57 at 127
