Re: 4 spd leaking
[Re: 70b5bird]
#760030
07/28/10 11:56 AM
07/28/10 11:56 AM
Posts: 4,285 Ohio
64dodge572
Ohio
You need to remove the cap first and remove the spring and ball. If not the ball falls in the trans and your going fishing. Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
Re: 4 spd leaking
[Re: 70b5bird]
#760033
07/28/10 02:48 PM
07/28/10 02:48 PM
Posts: 4,285 Ohio
64dodge572
Ohio
The ball won't fall out when you remove the cap. Use a mag to get the ball out of the hsg once you remove the spring. Dan
