68 DART upgrade backup/n safety switch??? #75931
06/19/08 12:10 PM
06/19/08 12:10 PM
eastern long island,NY
JeepJimmy Offline OP
68 dart. auto. has the "old" style single stud neutral safety switch. and the reverse light switch on the lower steering column, that is missing and broken pieces in the column. want to upgrade to a 3 prong switch in the trans. is this possible??
70 duster 360magnum, 1975 jeep j-10.
Re: 68 DART upgrade backup/n safety switch??? [Re: JeepJimmy] #75932
06/19/08 01:08 PM
06/19/08 01:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I believe in order to do that you have to change the valve body or at least the cockscomb that works the switch.
Re: 68 DART upgrade backup/n safety switch??? [Re: stumpy] #75933
06/19/08 01:09 PM
06/19/08 01:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thats at the minimum , a wiring harness mod is also going to be needed at the bulkhead
Re: 68 DART upgrade backup/n safety switch??? [Re: JohnRR] #75934
06/19/08 01:11 PM
06/19/08 01:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: 68 DART upgrade backup/n safety switch??? [Re: JeepJimmy] #75935
06/19/08 06:35 PM
06/19/08 06:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
To upgrade a '68 valve body for the 3-prong switch you need a roostercomb from a '69 or '70 VB, later years won't work; or upgrade the whole VB as suggested earlier.
