68 DART upgrade backup/n safety switch???
#75931
06/19/08 12:10 PM
06/19/08 12:10 PM
Posts: 1,271 eastern long island,NY
JeepJimmy
68 dart. auto. has the "old" style single stud neutral safety switch. and the reverse light switch on the lower steering column, that is missing and broken pieces in the column. want to upgrade to a 3 prong switch in the trans. is this possible??
70 duster 360magnum, 1975 jeep j-10.
Re: 68 DART upgrade backup/n safety switch???
[Re: stumpy]
#75933
06/19/08 01:09 PM
06/19/08 01:09 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I believe in order to do that you have to change the valve body or at least the cockscomb that works the switch.
thats at the minimum , a wiring harness mod is also going to be needed at the bulkhead
[Re: JeepJimmy]
#75935
06/19/08 06:35 PM
06/19/08 06:35 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
To upgrade a '68 valve body for the 3-prong switch you need a roostercomb from a '69 or '70 VB, later years won't work; or upgrade the whole VB as suggested earlier.
