1978 904 Lock up trans torque converter #759261
07/27/10 12:27 PM
07/27/10 12:27 PM
Eastern Ohio
mopowergtx Offline OP
Eastern Ohio
Anybody know of someone that makes a 2000-2200 rpm stall for one? I called ACC and couldnt get through to a tech, emailed Dynamic, and emailed Frank Lupo but no response yet. Looked at TCI's website and didnt see anything. Didnt see anything on Mancicni's website or Summits. I got non-lock up 727's and 904's (need rebuilt) but prefer to keep the numbers matching trans in the car.
Re: 1978 904 Lock up trans torque converter [Re: mopowergtx] #759262
07/27/10 12:35 PM
07/27/10 12:35 PM
Staten Island, NY
Theorio1025 Offline
Theorio1025  Offline
Staten Island, NY
Try the tci part num 141350. Its advertised at 2000 rpm stall. The summit part num. is tci-141350.
Re: 1978 904 Lock up trans torque converter [Re: Theorio1025] #759263
07/27/10 12:45 PM
07/27/10 12:45 PM
Eastern Ohio
Eastern Ohio
Good find. I was using the model/make feature at Summit and striking out for anything. Maybe this is why.
Code Name Price
141350 904/A500 Breakaway® Lock-up Torque Converter 1982-up
Thats the info from TCI's website. So Lock up started in 1978. What gives from then till '82 that TCI doesnt list it to cover '78-'81?
Re: 1978 904 Lock up trans torque converter [Re: mopowergtx] #759264
07/27/10 02:02 PM
07/27/10 02:02 PM
Eastern Ohio
Eastern Ohio
Hello- We recommend our 11" 904 Lockup, built for a stall between 2000 and 2400 rpm. This is a $365 ($435 List) piece, and if you wish to order it, please have engine size and balance weight handy......
Got this back from Dynamic.
Re: 1978 904 Lock up trans torque converter [Re: mopowergtx] #759265
07/27/10 02:05 PM
07/27/10 02:05 PM
Staten Island, NY
Theorio1025 Offline
Theorio1025  Offline
Staten Island, NY
Yeah I've noticed the make model feature from summit doesn't work very well for mopars. If not try calling tci to make sure it will work properly.
Re: 1978 904 Lock up trans torque converter [Re: mopowergtx] #759266
07/27/10 03:42 PM
07/27/10 03:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If all you're looking for is 2000-2200 the factory converter should do that...depending on your power.
