Re: Need help with a 96 Jeep, Power all the time windows??
[Re: Hoop]
#758832
07/27/10 01:01 PM
07/27/10 01:01 PM
Posts: 2,190 SW MO
closer9
SW MO
Since all the power accessories work, and the wheel won't lock, my guess would be in the ignition cylinder and linkage to the switch. Sounds like the switch is staying in the accessory position...
Daily: '19 Frontier 4WD Belle: '67 Belvedere Convertible, 318/727 in Go ManGo! Other: '64 C10, 283/3 on the tree
[Re: Hoop]
#758833
07/27/10 02:18 PM
07/27/10 02:18 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
I agree with the diagnosis that the ignition switch is staying in the accessory position. I have a 96 Grand Cherokee and everything except the power door locks go off when the key is off/in lock position/ removed !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: closer9]
#758834
07/28/10 09:11 PM
07/28/10 09:11 PM
Posts: 489 Partridge, KY
Hoop
Partridge, KY
but if its staying in the accessory position, can it steel start & run, because it douse start & run?
[Re: doctor_mopar]
#758835
07/30/10 09:31 PM
07/30/10 09:31 PM
Hoop
Partridge, KY
took the the key switch out & un pluged it, hooked the battrey back up & it steel has power on the door wendows, did find a ground wire un hooked behind glove box, so I boted it down with another ground, but that did not change nothing! Had front door panels off, it all look stock, under the steering wheel looks stock, dont look like its been rewired! I'm stumped???
